1700 Resurrection
   / 1700 Resurrection
Thanks for the pages. I've read all about it in the FO-40 but still doesn't mean much. It's clearly a non-OEM replacement. I'll just poke around with it and hope I don't fry anything. Thanks JC!
   / 1700 Resurrection #32
Why don't you post a pic of your alt rear with whatever wiring attached to it. Somebody might find a bit of useful info..You never know. Did you follow the wires from Voltage Regulator back to alt?
JC,
   / 1700 Resurrection #33
Do you know if the alternator is internally regulated? Makes a big difference. Do you have any info on the alternator, manufacturer or maybe a photo? Just a guess here but ,
E is for excite, hot wire to excite the fields.
S is for sensing or Stator, may go to charge indicator light
B is for Battery, should be a heavy wire going to hot battery cable on solenoid.
L , no clue
   / 1700 Resurrection #34
Alternator is external from factory. It is common for people to sub a cheaper alternator with internal regulator.
   / 1700 Resurrection #35
Any updates??
   / 1700 Resurrection #36
I hope my monkey wrench gremlin did not pay RedDirtDaddy a visit!!
JC,
   / 1700 Resurrection
Evening folks! I'm terribly to sorry to have abandoned my thread. I'll post a detailed update when I'm not on my phone with $#%! signal. Haven't had too many opportunities to work on this beast but am close to being done. Quick question, does anyone know a cross referenced replacement bearing for the steering shaft? The one on top of the clutch housing. That's really my last missing piece.
   / 1700 Resurrection
So here's the latest and greatest:
Engine was overhauled, new rings and bearings, valves replaced
Clutch replaced
New fluids and filters
New starter solenoid
New (ebay) alternator (not currently hooked up, unsure how)
New battery and cables
Got her all back together but she won't start. She'll turn over just fine and give small puffs of white smoke but just won't catch. I'm using the preheat (key held to the left) and have verified voltage at the plugs. I've bled it a couple of times and it seems to not have any more air.
What am I missing??
   / 1700 Resurrection #39
I think you need to bleed the system again. Follow the link provided and look at diagram. Read my post #6 and 7 (picture) for instructions. If you didn't do everything in these instructions, do it again. http://www.tractorbynet.com/forums/...258-ford-1600-died-know-wont.html#post1730983
After bleeding try to start at full throttle and when it starts lower throttle to between 1000 to 1500 rpm for 1 or 2 minutes. It should run fine after that.
   / 1700 Resurrection
Thanks Ray! Gave her a shot this weekend, no dice. I'm getting fuel to the injectors but not through. Pulled them out and connected lines and there's no mist at all. There's nothing that jumps out as to being bad or wrong with the internals, other than the tips having some carbon. Guess I'll get some solvent after the needles and their seats then see what happens.
UNUSED FUTURE MINI SKID STEER (A58376)
UNUSED FUTURE MINI...
BOAT TRAILER (A58376)
UNUSED CHERY INDUSTRIAL 14' BI-PARTING IRON GATE (A58376)
UNUSED CHERY...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
2016 Chevrolet Express Shuttle Bus (A56858)
2016 Chevrolet...
2007 Yamaha Rhino 660 (A56436)
2007 Yamaha Rhino...
