New Grapple exceeds expectations
   / New Grapple exceeds expectations
As long as your are a satisfied customer, that's what counts.
Suggest you have adequate counter weight at all times.
Your exactly right. the land-pride 1872 was a little light counter weight for the heavy stuff. My Box blade or Backhoe should do it though. May have to invest in a heavier Bush hog like the 296.
Thanks! I'll have to look into getting one. That price isn't as high as I was expecting.
Your welcome. Skidsteer solutions also markets the anbo as well. I bought one from there back in 2008 for an M59 I had at the time. It weighed 1250 Lbs and was 74 in. I bought this one from Anbo though.
   / New Grapple exceeds expectations #23
Sounds like you have all you need in counter weight and the backhoe is probably the best not only in weight but how you can position it to best counter balance.
I thought yours was a 72?
Mine is a 72. Anbo makes several models of the 72.
1. GR-L 440lbs 18-30 Horsepower Tractor
2. GR-M 370lbs 20-45 "
3. GR-S 780LBS 30-85 " Which is mine
4. GR-SH 1005LBS 50-120 "
5. GR-X 1270LBS 50-160 "
   / New Grapple exceeds expectations #26
Now I understand. Do you have the website address so I can look at them.
   / New Grapple exceeds expectations #27
I think the 'root rake' feature is nice at 72", but I really don't think a grapple has to be that wide to be VERY effective. Sometimes the width can be an annoyance because on uneven terrain, you may not be able to grab something without repositioning or dragging the object. However, I use my rock bucket grapple's finger tines to spread and smooth dirt & gravel much like a rake. You'll be able to do the same with that root grapple.
I think the weight of your grapple is fine. My root rake grapple weighs almost 800 lb and it sticks out way beyond where your grapple does. Most of your weight is very close to your loader arms so you have much more usable lift. Besides, in reality with a grapple, you don't always get the darn thing full with each load. Mostly, it's just how fast you can grab and move stuff without having to get off the tractor. I just grab what I can and save the rest for the next load. I can do in a couple of hours what it would take a month to do by hand. That's the value of a grapple. Since yours is heavy duty, you will do less damage to it no matter how hard you work. You found that out when you hit a rock. To me, a root rake/grapple with vertical teeth needs to be tougher than a bucket type debris grapple with horizontal tines. If your tractor can lift 1800 lb and the grapple weighs 800, you still have a massive payload capability.
EDIT: I forgot to say that I didn't load my rear tires until I got a rock rake grapple. It convinced me in a hurry to load them and always ensure I also had a heavy boxblade on the rear 3PH.
Yes, I agree with the loaded tires. My M59 was loaded. I am going to check on about getting the L45 loaded as well. Also the good thing about getting the width as wide as your rear tires is when your clearing trees and debris or moving them forward, it allows you to keep going with out running over logs trees etc. with your Tractor. I found this out this past weekend. This allows your Bush Hog to cut freely as you go.
   / New Grapple exceeds expectations #30
jinman your tractor is very similar to mine so I was wondering which grapple you purchased?
2000 Ford F-650 TMA Attenuator Truck (A49461)
2000 Ford F-650...
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
KUBOTA M7040 TRACTOR (A51406)
KUBOTA M7040...
UNUSED FUTURE MINI EXCAVATOR HEDGE CUTTER (A51244)
UNUSED FUTURE MINI...
Vermeer 554XL Round Baler (A50774)
Vermeer 554XL...
UNUSED X-STAR SKID STEER QUICK ATTACH LAND LEVELER (A51243)
UNUSED X-STAR SKID...
