L45 Hydraulic Accessories
/ L45 Hydraulic Accessories #1
avc8130
Northern, NJ
Kubota L45
I am picking up a used L45 and I want to get to work over the winter on equipping it with some hydraulic goodies.
1. 3rd Function
2. Hydraulic Thumb
3. Rear Remotes
Could someone that has an L45 with these options post some pictures of the various valves/switches/mounts/etc?
I'd love to just drop the machine off at Kubota and have them install it all, but I don't think I could ever convince myself to pay their probably $10k.
Also, is there anything you would change about the way Kubota/your dealer did the install?
Thanks!
ac
/ L45 Hydraulic Accessories #2
Check out a thread I have titled "New L45 has arrived" to see what I have done to mine.
Lauren
Lauren
Lauren,
I searched for your thread, any chance you could snap some pics of the 3rd function on the front? That is what I plan to tackle first.
Specifically: valve and valve location, handle and anything else that might be helpful would be amazing.
How are you liking your 45?
ac
/ L45 Hydraulic Accessories #4
Hi AC
Here a couple of photos of the Kubota 3rd function for the loader. As you can see you get a new loader handle with two buttons underneath - you press one button to open and the other to close. These buttons operate electric solenoids I believe so at the base of the lever on the right you will see a round yellow light in the photo. The light indicates that the 3rd function is on - push the light/switch and it will turn off and the lever buttons will no longer function. The second photo shows where the quick connects get mounted on the loader. I have been working in a very muddy area for the last couple of weekends so the L45 really needs a bath.
L45 3rd function loader handle 121210.jpg L45 3rd function loader quick connects 121210.jpg
I know the Kubota 3rd function solution is not cheap but I think it is far better than having another valve to deal with. The buttons are very handy and allow you to open and close the attachment as you are raising and lowering it if need be. I would not want to have to deal with a separate valve and lever.
The actual title of the thread that has a lot of photos of things I have done to my L45 is actually titled "New Kubota L45 has arrived". Even if you just search for "L45" it comes up on the first page. I have made some additional changes since my last post and will be adding a post or two to the thread soon as it is my repsitory of all things L45.
I really like the L45. It seemed a lot bigger than my B21 and B26 when I first got on it but I have put almost 260 hours on it this year and have enjoyed everyone of them and grown accustomed to its larger size - and power. I would prefer a B26 sized tractor with the L45 hoe and a 2,000 pound lifting capacity on the loader but I have been able to get the L45 into all the places I needed to this year.
I live an hour north of Toronto in Ontario and I just can't take the cold like I used to be able to so I bought the L45 with the Laurin cab. The B26 had all the options I have on the L45 except the rear remotes but the Laurin cab is almost the same price for either machine and I decided that this was going to be my last tractor purchase and I would rather have the space of an L45 then be confined in a smaller cab on the B26. I have had the cab on for a couple of months now and it sure is nice to have heat and be out of the wind.
The only down side to the L45 is that it definitely burns more fuel in a day than the B21 or B26 but you can also get substantially more work done so I think it balances out. Me neighbours have also commented on how much quiter the L45 is than the B21 or B26 and I think a big part of that is the Auto throttle as the machine is not running flat out when you are just using the loader.
I think you and your wife will be very pleased with the L45. I do a lot of digging with the hoe and a lot of loader work and my property has some very steep grades and I love the HST+.
Enjoy your L45.
Regards,
Lauren
Lauren,
I GREATLY appreciate the photos you posted, as well as the commentary. I put a factory Kubota kit on my L39, and I just couldn't see the point spending $840 on an aftermarket one when $885 buys me one designed for my machine. A few questions:
1. Are the lines for the 3rd function hard line along the loader or are they hose?
2. What type of couplers came with the setup? Flush face skid steer or agricultural?
3. Did you buy your machine with the setup installed?
ac
/ L45 Hydraulic Accessories #6
Hi ac
The hard lines run along the underside of the left llader arm.
The kit came with couplers that are not flat faced.
The dealer installed the kit as part of the deal. As I recall it was only a couple of bours labour.
Lauren
Hi ac
Lauren
Lauren,
Wow, that's a nice change. The Kubota kit I put on my L39 was all hose.
I was quoted $150 for labor to install, so it must be ~2 hours.
ac
1984 Cheetah Chassis Corp 53ft. 32 Ton T/A Container Chassis Trailer (A61568)
1984 Cheetah...
Cat CB24B (A60462)
Cat CB24B (A60462)
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
2001 Challenger 35 ton Flatbed Lowboy Trailer, VIN 1W8B21D261S000473 (A61166)
2001 Challenger 35...
UNUSED IRANCH MINI HYD THUMB (A62131)
UNUSED IRANCH MINI...
Adkins Service Bed (A61165)
Adkins Service Bed...
