Thomas
Epic Contributor
- Joined
- Apr 6, 2000
- Messages
- 31,774
- Location
- Lebanon,NH.
- Tractor
- Kubota B2650HSD w/Frontloader & CC LTX1046 & Craftman T2200 lawn mower.
WayneB said:Thomas is that on your tractor? I do have a blade (not sure where I got it from, but it is approximately 6' and has a old frame with it) and I was thinking of doing the same thing you did. Was worried about having the blade that far out infront of the bucket? Any other details?
Wayne
Morning Wayne.
Yes that's my little mule of 11 years.
I added weight box ooohhh about 150lbs and never had problem of the rear end being to lite.
The top pins I only use when scraping...tilt bucket to added down pressure on blade.
Little advice...attach piece of flat steel about 3/8" thick on the backside of the bucket for support to help out plow frame,also try have the back side of the plow rest against the corner of the bucket when the plow set at 45 degrees,for that will give support.
