raising trusses for pole barn
/ raising trusses for pole barn #21
I did this by myself for 12' walls on my garage using a 'man lift'. Reason I didn't rent a heavy duty forklift was the distance from the rental place. I could easily attach the man lift to my truck and get it home. My trusses were 'attic trusses' with a 12/12 pitch so I had to get quite high and let me tell you, I won't do it again. Took me a weekend to do it and the last few, especially the ladders were a real pain. I would rent a crane next time and get another couple guys to help. Installing trusses by yourself is challenging.
/ raising trusses for pole barn #22
Those can be easy to damage.
The truss plates tend to want to bend on the bottom cord, where the center splice is, if they are picked up improperly.
/ raising trusses for pole barn #23
I was kind of thinking the same thing. I own a 35' tow behind boom lift, but have never used it to set trusses. The bucket capacity is only 500 lbs., so I guess it would depend on the weight of a couple of guys plus the truss.
If that wouldn't work I'd suggest a snorkel type lift. I'm thinking much more weight capacity. Fasten the truss to it, have a couple guys in the basket and a guy on top of each wall to follow your layout marks and make sure it's OK for side to side fit.
/ raising trusses for pole barn #24
I used my 65 MF with a telescoping boom on it for 12' high walls and had 4 helpers, it went very fast.I think the boom might have been designed for a 3 pt. hitch but I put it on my front end loader. I borrowed it from a guy at work.
/ raising trusses for pole barn #25
This is how I did it for 12 ft trusses . 4" pvc pipe over a single Paynes fork. Worked great
1999 MACK MIXER (A65643)
1999 MACK MIXER...
Speed Trailer (A64194)
213088 (A64276)
213088 (A64276)
2016 P.J. Trailer Trailer, VIN # 4P5F8202XG1252798 (A65563)
2016 P.J. Trailer...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
Case CX75C (A62177)
Case CX75C (A62177)
