Septic Tank Maintenance
/ Septic Tank Maintenance #1
Bob77064
Elite Member
KY @ TN line
2011 LS R3039
We have a septic tank, about 6 years old. This is the first septic tank I have had. Is it a good idea to use RidX, baking soda or something like that for maintenance?
/ Septic Tank Maintenance #2
You don't need to add anything besides organic waste since that contains the bacteria you are looking for. Probably should have it pumped and cleaned every 3-6 years depending on use.
/ Septic Tank Maintenance #3
It's not so much what you think you should add (which is nothing, really), it's what you don't want in the tank. Example, if you use a garbage disposal, have your tank pumped more frequently (2-3 years, depending on your family's size). Use septic system friendly detergents. Never put bleach down a commode. Things like that.
/ Septic Tank Maintenance #4
This how I found mine yesterday. It needs some maintenance :)
/ Septic Tank Maintenance #5
As Roy said, watch what you put down the drains. If you have a garbage disposal, about the only thing you should chop up is ice. Grease, potato peels, carrot peels, etc. should be put in the garbage or thrown outside. In the city, the wastewater plant deals with it much better. In your septic tank, you have to deal with it. Cost to have our tank pumped is about $200. I have it pumped every 2 or 3 years. Much cheaper than a new system, especially with the health department rules in our county. If you haven't had it pumped yet, I would suggest you do it soon. Bacteria naturally occurs and grows in the tank. Adding bacteria should not be necessary most of the time. I have heard of some concerns with anti-bacterial soaps, but have not seen any independent studies on whether they are a concern or not for a septic system. Probably not enough use of the soaps to hurt the system. Good luck.
/ Septic Tank Maintenance #6
Exactly. Not trying to be crude, but when you sit on the pot, you're giving your septic tank what it needs. I was a licensed septic system installer for years, and you wouldn't believe the "snake oil" stories that I've heard.
RidX, and similar organic products won't hurt your system, but they are a waste of money.
Roy is absolutely correct.
One thing that I would add is, put garbage in the trash can, not down the sink drain. And, NEVER NEVER pour grease down the drain.
Also, most drain cleaners are acidic. Acid is bad for your bacteria. The best policy is to not put food and grease down the drain in the first place.
Now, YOU have a problem. :D
/ Septic Tank Maintenance #7
The funny thing is we were planning on moving the tank because we are fixing to build a packing shed with kitchen for processing vegetables. We just are starting a little sooner, I won't have to poke around the yard to find it. Who wants to help???? Peanut butter sandwiches and water will be provided.
/ Septic Tank Maintenance #8
Yes, I would say you need it immediately! Sorry for the problem you have. We have our system pumped every three years and it has been in since 1985 with zero problems. I do have a garbage disposal that injects a bacteria into the system each time you hit the on switch. Everything is fine as of now.
Down the road from us we had a system fail, I assume it was never pumped and the guy had a water softener system that he auto back flushed and pumped into his septic tank. Costly situation for sure.
Wayne
Thanks for all the help guys, I will get it pumped.
/ Septic Tank Maintenance #10
Had septic for years. Never added anything. Never put grease down the drain. Took out the garbage disposal.
Plenty of info online about how septic works, and when it might be wise to have it pumped. I have a cabin used perhaps 10 percent of the time. Have it pumped every 15 years and it has been perfect. Home septic is pumped every 8 to 10 years - and could go longer. Septic systems are sized for the number of johns, etc. We have 3, but there are only two of us. In an earlier home, with 4 johns and 7 people, we were on a 6 year cycle.
Common sense and a conversation with a reliable septic man will do wonders.
/ Septic Tank Maintenance #11
Keep some empty juice or tomato sauce cans under the sink. It's so easy and tempting to drain ground beef down the drain, but that's very harmful to your system. Use foil on baking dishes and let the grease cool and harden. Throw the foil away, or scrape the cooking utensils before washing. Use a sink strainer and throw away or compost everything it catches.
/ Septic Tank Maintenance #12
The guy who pumps my septic system said to put a package of yeast down the toilet nearest the tank 4 times a year for insurance. When the seasons change I put a package of yeast down....cheap insurance.
/ Septic Tank Maintenance #13
Haven't seen any bad info given here. We do give the tank a little dose, maybe a cup full, of RID-x every few months. Look at it as low cost insurance. There is a large variety of stuff going down the drain that needs to be addressed. As mentioned, lots of different kind of chemicals, grease and food mater find their way into the tank and TP is wood. Just to insure an adequate variety of bacteria and enzymes in an adequate qty, something like Rid-X helps if they are not thriving on their own.
/ Septic Tank Maintenance #14
My parents neighbor was in the septic pumping business. He told me many systems don't need to be pumped nearly as often as the 2-3 years that is generally recommended.
Soil conditions, installation, type of system all play a part in how often you need to have a tank pumped but it often comes down to what you put down the drain. As others have posted garbage disposals, water softeners, drain cleaners, and types of soaps or detergents can all have an effect as well.
/ Septic Tank Maintenance #15
Around here the county sends a letter every three years and pumping is mandatory or you get fined. It is a good idea anyway so I don't quack. But is irritating if the house is empty 6 months a year. There should be a turd-meter on the system that gives an alarm after a certain number. :D
/ Septic Tank Maintenance #16
I just had my aerobic septic system pumped on Wednesday of this week (after 11 years). Since it is four tanks (raw, aeration, filter/treatment, and sump - about 1500 gal) the cost was $300. This company usually charges $325, but they gave me a $25 discount because the driver and truck are actually based close to my house and they had such a short drive to get here. I called around 10 AM and they were here by 12:30 PM on the same day.
My aerobic inspector had told me that solids were starting to get into the filter area and sump. The clean water sump had maybe 6" of sludge in the bottom and the filter was starting to have a little brown sludge collect on it. The pumper truck was concerned about driving over the line between my sprinkler heads, so he stopped the truck and strung an extra hose section to the tanks. It was a very easy approach for the truck with no trees and firm ground. The guys on the truck said my system needed pumping, but it was very clean with absolutely no grease or other trash in my tanks. Actually, in the clean water sump, there was a cow insect ear tag that fell into the water. I tie tags just inside the tank access covers and it keeps fire ants away. Somehow the tag got loose and dropped into the tank. They sucked it up without a hitch. The guys went out of their way to backwash the tanks and get all the sludge. I gave them a fresh water hose with spray nozzle and they used that to help too. They were careful to keep sludge out of my yard and and not leave any stinky mess. I really appreciated the job they did, so I gave them each a $10 gratuity and thanked them for the great job.
I have a sign that I love to put in my bathrooms near the commode, but my wife won't let me put it up. The sign says, "Don't put anything into the toilet that you haven't eaten." That pretty much wraps up my theory of keeping a septic system healthy. I run my laundry water out as gray water and don't put that through the tanks. That helps keep the bacteria high and the soap sludge low. Of course, dish water also has soap, but it can't compare to boxes and boxes of powered detergent. We use our garbage disposal too, but mostly for meal residues washed off of plates and some vegetable trimmings. Most of our prep cuttings and peelings go into the trash can. If it's greasy, it gets wiped with a towel before going into the sink or dishwasher. We collect oils/grease from cooking in a can and put that also into the trash. Not using the toilet as a trash can is a big thing. Clean wipes/baby wipes are the kinds of things that wreak havoc on a septic system. I learned that the hard way when my aerator pump started making noise and popping the breaker. I found a Clorox wipe wrapped around its shaft making it off balance and drawing excess current. It only took one careless disposal to gum up the system.
/ Septic Tank Maintenance #17
Jinman you are the first here to mention gray water. I had to hand dig to install my home built septic system almost 20 years ago that handles 1 to 15 people for 6-8 months a year. Only time it ever failed and I had to pump it was when we had company dumping a bunch of stuff down the toilet. I think the only reason it has worked so well for so long is toilet is the only thing that goes into it everything else goes in the grey water sump.
/ Septic Tank Maintenance #18
No one has mentioned "female products"! Probably the worst thing for septic systems.
I had my 37 year old system pumped out and inspected last year. ($235.00)
I have owned and been using it for 13 years and it didn't really need to be pumped out but I put in a new Manufactured Home and it's part of the process.
It took the state inspector 3 weeks to approve my system. He could not find any reason to condem it. (he sure wanted to!)
/ Septic Tank Maintenance #19
Do they require all septic systems to be pumped that often, or just aeration systems?
My conventional system hasn't been pumped in the 31 years I've been here. In fact only a handful of the 40 or so neighbors have had theirs pumped in that time.
I had a rental in an area with much different soil type that I had to have pumped every 3-5 years.
/ Septic Tank Maintenance #20
As of 2013, our area will require tanks pumped out every 4 years. They'll also require the manhole have risers to bring access above grade. As far as why...good question.
