How to bleed steering system ford 3910?
   / How to bleed steering system ford 3910? #11
You will have to crack the pressure lines that feed pump with tractor off allow fluid to weep by threw fitting then tighten nuts start tractor and crack loose return lines after air is out and starts forcing fluid out tighten nuts then move steering to left then right allowing valve body to eliminate all air should be fine note if you run pump dry depending on pump a vain pump has carbon fiber impellers which will heat and wear impeller where it will allow fluid to flow past it meaning instead of pushing the fluid it sweeps riding over so impellers aren't against valve body wall forcing fluid in one direction you may want to put an additive in pump directly to lubricate impeller.
Got the scoop from a mechanic who works on these. IF you pull the steering gear/valve housing off the tractor, it has to go back together in a certain order or it wont be synced up and it will lock up the steering. Hauling it in. Said it should cost less than $300 AND he will change out the gasket+ O-ring in the leaky fuel pump.
Thanks for all the help but I am throwing in the towel and having the mechanic fix this one.
PENDING SELLER CONFIRMATIONS (A51219)
PENDING SELLER...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A51039)
2016 Kawasaki 70...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50324)
2020 Kubota Z723KH...
2015 MACK GU713 WINCH TRUCK (INOPERABLE) (A50854)
2015 MACK GU713...
2013 LONE STAR TRAILER MFG. (A50854)
2013 LONE STAR...
2013 HINO 388 (A50854)
