front tire roll-off question
/ front tire roll-off question #1
lew61
Eastern Sierras, CA
Kubota L4240HST
As a newbie, I've noticed a few references to front tires rolling off their rims and I'm wondering what steps, if any, can help prevent this. Also, what's involved in reseating a tire? Are there special tools I should have on hand? :confused3:
/ front tire roll-off question #2
Proper inflation prevents it. A heavy duty ratchet strap tightened around the tread of the tire will make it easy to pump up if it comes off. A big air compressor helps.
Here is a video, the same work on a tractor tire.
Ah, preventative maintenance. That's music to my ears. Thanks!:thumbsup:
/ front tire roll-off question #4
>Proper inflation (plus a few pounds more with a heavy load in front) has already been discussed.
>No sharp turns with a heavy load in the bucket.
>No sharp turns on hard ground - especially asphalt or concrete.
>Slow turns. Fast turns tend to increase the weight on the front outside tire and cause the sidewall to flex - possibly off the rim. It is just like a car cornering.
I've only had it happen once and thereafter have been very observant about the air pressure. Note that "heavy load on the bucket" is a prevalent factor.
/ front tire roll-off question #5
Anyone use a bead sealer?
I noticed the tire shop used some on the last set of tires on the truck.
/ front tire roll-off question #7
I used tubes. They stop the sudden loss of air if the bead is broken while doing any of the above mentioned items.
/ front tire roll-off question #8
One other point besides what the others said. Watch out for low-cut stumps, large rocks sticking out of the ground or similar things that can catch a tire when you're turning. That's a pretty common problem with wheeled skid steers and also can get a tractor's fronts off their rims.
/ front tire roll-off question #10
I too used tubes. Anyone here feel this may be a problem?
For me it was, possibly to do with gw's points above. When trying to cure a slow leak in a BX24 front by using tubes I had 3 sudden failures of the tubes. It was thought to be due to the wheel spinning on the tire so went back to tubeless. One comment was that the front wheels are just too small for front loader work. Have tried cleaning up the rim, new valves, and most recently slime but still drops a pound or two of pressure a day. Now waiting for a new wheel/tire combo to replace the useless one.
I am really appreciating this forum. Thanks, one and all, for your inputs. :thumbsup:
/ front tire roll-off question #13
I have only ever thrown a front tire when I had a slow leak and ran the tire on near-to-zero PSI without noticing it. Raise the front of the tractor and use the afore-mentioned ratchet strap method to re-seat the bead. Easy-peasy.
Neither of my front tires hold air consistently, and it is a bit annoying. I am pondering putting tubes in. As-is, I have to top off the front tires every time I do any work.
/ front tire roll-off question #14
I see a lot of different tractors in your signatures, but am wondering, is this more common with the BX1800's which have the smaller front tires or do they work ok?
/ front tire roll-off question #15
I'm not sure if it was tire size that caused it but it was a common complaint for the BX1800 and 2200 series in the past. The front tires on my BX2200 were constantly low until I green slimed them. My new BX25 doesn't seem to suffer from this issue but I've only had it for a couple of months.
/ front tire roll-off question #16
Our front tires came off countless times until I tubed the tires.
/ front tire roll-off question #17
Was the valve stem ripped off the tube? If yes then you probably spun the tire on the rim and this can be caused by to low of pressure or lots of traction available to that tire trying to pull/push the rest of the tractor around.
/ front tire roll-off question #18
The previous owner of my 855 had the front tires filled with foam ,no tire pressure issues at all and the chance of them rolling off the bead is 0 ! probably would be a rough ride if you only drive on pavement but hey it's a tractor not a Porsche ! 037.jpg
/ front tire roll-off question #19
^I'll consider foam with the new tractor purchase. But I can't ever remember ever having a problem with tires until sometime in the 90's. Then it seemed all at once and on cue tires became undependable. You could no longer take a new tire for granted.
/ front tire roll-off question #20
Bobcat said not to run foam filled tires in the CT235 I had.
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2016 Deere 180G (A60462)
2016 Deere 180G...
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
36" X 72" CONCESSION DOOR (A62131)
36" X 72"...
Genie S60 Boom Lift (A64047)
Genie S60 Boom...
