Deere synthetic oil?
/ Deere synthetic oil? #1
bbraud6
Prairieville, louisiana
john deere 4120
About to do my first oil change on 4120, 54 hours on clock. Talked to dealer he says either 15w-40 or 0w-40 full synthetic will work and are recommended. Also said the full synthetic allows you to extend the change interval. This is my 4th deere compact and always used deere 15w-40 with no problem. Just curious if anyone is using 0w-40 synthetic and how do they like it. Parts guy at dealer said price difference is not that much would be fine to use right out the gate on new engine.
/ Deere synthetic oil? #2
I use Deere full syntheric 0W40 in five tractors and have for about four years. It is great in that winter starts are like summer and warm up is quicker. Because of my experience with synthetics in other vehicles I believe I have higher oil pressure and better coverage in stress activity for the tractor. Oil intervals are definately extended and where I would normally do one in mid summer i only hav eto do my annual oil change. So that basically cuts the price in half by extended intervals. I also see that the engines run cooler as well.
Not to butt in my my experience with Deere owner's manuals is that the change to synthetic should be after 100 hours and not before. I have seen this in print and is common knowledge among Deere guys around here. Unless I actually saw something in print that specifically mentions your model tractor, i'd go dino on the next change. You could also email Deere directly and they will address the issue. Just my two cents here and while I see you are from Louisiana, let me say i loved the time I spent there back in the early 1970's. Great food, lovely women and friendly people.
Thank's, that was my plan to use 15w-40 on the first change and synthetic from then on. I've used synthetic on my trucks in the past with good results but this would be the first time i use it on my tractor. Yes i love living in louisiana, weather has been great here lately, lows in the 40's highs upper 60's. Only drawback would be the occasional hurricane but being a lifelong resident you get used to them.
/ Deere synthetic oil? #4
Concur, use fossil fuel during the break-in period. Synthetics are slippery enough to actually inhibit break-in. But until the FT4 engines come out, I still think synthetics are a waste of money. Once particulate filters are introduced, the soot that has historically turned diesel engine oil black - becomes a thing of the past. If you want to shell out the bucks for expensive synthetics, that's your business. But for my money, regular 15W40 is good enough for any diesel compacts prior to FT4.
//greg//
/ Deere synthetic oil? #5
The cold starting is where synthetics shine. Run them as soon as you can, and for the little cost differance over dino, really worth the investment.
/ Deere synthetic oil? #6
Concur, use fossil fuel during the break-in period. Synthetics are slippery enough to actually inhibit break-in. But until the 2014 models come out, I still think synthetics are a waste of money. Once particulate filters are introduced, the soot that has historically turned diesel engine oil black - becomes a thing of the past. If you want to shell out the bucks for expensive synthetics, that's your business. But for my money, regular 15W40 is good enough for any diesel compacts prior to 2014.
//greg//
The oil still turns black because of the egr. DPF does not eliminate this. And many tractors already have egr's On them now.
/ Deere synthetic oil? #7
Will is correct. The DPF removes soot as it is exiting the exhaust. Engines with DPF mufflers are running higher levels of EGR which soot loads the engine due to the cooler combustion temps. That is why they had to upgrade oil classifications and quality for when EPA 07 took place.
/ Deere synthetic oil? #8
That is why I prefer the SCR route, minimal EGR and maximum SCR, and the SCR does the rest. A much simpler more efficient solution.
/ Deere synthetic oil? #9
Exactly Will. I would never buy any dpf equipped engine without scr (urea.)
You only have to look at International trucks MaxxForce engines to see how mass egr worked out for them, lol.
/ Deere synthetic oil? #10
Keep in mind that by the time we are at final stage Tier 4 all the engines will have scr plus egr plus particulate filters. Enjoy your simple engines now.
/ Deere synthetic oil? #11
And that's what I was talking about. I thought when I mentioned particulate filters, that DEF would be understood. I believe those other guys are talking about IT4 (interim Tier 4). Here's John Deere's implementation schedule for FT4 engines:
25 to 49 hp (19 to 36 kW)..........2013
50 to 74 hp (37 to 55 kW)..........2012-2013
75 to 174 hp (56 to 129 kW)......2015
175 to 749 hp (130 to 559 kW)..2014
750 (560 kW) and larger.............2015
//greg//
/ Deere synthetic oil? #12
Anything under 25 hp will not have scr. Lots already have egr, and they have been using it on the HHP tractrs for a while now.
Thanks for the responses. I was planning on upgrading my old 3320 deere due to acquisition of more property and needing more tractor and hp. Pulled the trigger on a new 2012 4120 couple of months ago with 400cx loader and rear remotes to get ahead of full tier 4 emissions which my dealer said would be on 2013 deere compacts with an additional bump in selling price to compensate for the emmision technology. So far loving this tractor, much more grunt than the 3320. This is my first deere with the turbo powertech engine after owning deere compacts with the yanmar engine. So far i am loving this tractor!!!!!!!
/ Deere synthetic oil? #14
In spite of all the emissions crap the drive ability of the new engines is miles ahead of the engines of 20-30 years ago. The torque is quite amazing. It is just too bad things have gone overboard with emissions.JMHO
/ Deere synthetic oil? #15
I agree. I prefer the DCR route over the cooled EGR that JD uses. Either way, the engines are leaps abd bounds better than they ever have been.
Giyi Mini Three-Tooth Ripper (A62183)
Giyi Mini...
2012 John Deere 6430 102HP Agricultural 4WD Tractor (A61572)
2012 John Deere...
Sakai SV505 (A60462)
AGT SA11100 Pallet Forks (A62183)
AGT SA11100 Pallet...
BLANTON PULL TYPE DRAG HARROW (A63290)
BLANTON PULL TYPE...
LEINBACH POST HOLE DIGGER (A63290)
LEINBACH POST HOLE...
