An "axle-surrounding" type backhoe subframe
/ An "axle-surrounding" type backhoe subframe #1
len10
Member
Southwest Connecticut
Terracyclone (Luzhong TC254)
I have a Luzhong TC254 (similar to a Jinma 254) with a loader and 3 point hitch mounted backhoe (LW-6). Having never owned a tractor, I had no clue as to the benefits of a subframe vs. a 3 point hitch mounted backhoe . Much of my inspiration for tackling this project came from dfkrug. His thread is here: http://www.tractorbynet.com/forums/build-yourself/171760-how-build-your-own-custom.html
In his thread, dfkrug describes two major types of subframes used to mount backhoes, a ladder frame and an "axle-surrounding" frame. After researching every subframe design I could find, I decided to go with 殿xle-surrounding type subframe. I created an amalgamation of all the design features I liked in the various designs I came across. The information dfkrug provided in his posts was invaluable. I hope my design might help some with a similar style tractor.
This was my first venture into metal fabrication. I had help from an experienced welder (not in the design phase), however, if could do it anyone could do it. Although it took much longer than I thought, mostly due to my work schedule, it was a rewarding process.
I first made some crude plywood templates as seen in the following pictures.
I had to remove the star shaped hub, so I could slip the template over the square axle housing (see picture).
Re: An "axle-surrounding" type subfram
The next picture shows a test fit of some of the components I made. The vertical plate is 5/8 inch steel. It is the main anchoring component and will be attached at multiple points to the tractor. It will be attached to the axle housing using the same bolts that attach the 3 point hitch as seen in the photo. It will also be attached to the loader subframe and ROPS. In addition it will be attached to the drawbar mounting holes by a 9 inch by 1/2 inch plate that runs under the tractor. I'll try to show these attachment points in subsequent posts.049.JPG
The U bolt seen in the previous photo was replaced by 2 grade 8 bolts and an angle iron that will be bolted to the 5/8 inch plate. It will also be bolted to a 3 inch by 1/2 inch bar that runs up to the bell housing.030.jpg
The following pictures show the parts that make up the parts that attach to the tractor. The yellow arrows in the first picture point to pieces that belong to the loader subframe. The only modification I made to the loader subframe was to weld 1/4 inch plate to the sides of tube near the back for reinforcement.
Below is the 9 inch plate shown mounted under the tractor. The hydraulic oil plug is still accessible through the hole.
The 9 inch plate shown from another angle is bolted to the 5/8 inch main bracket.
A picture from the rear of the tractor showing the mounted bracket. The bracket is bolted to the axle, ROP, front loader subframe, fender bracket, and 9 inch plate.
The next set of posts will show the modifications made to the backhoe.
/ An "axle-surrounding" type backhoe subframe #7
I bought a new close out LW-6 Hoe on ebay that was still in the shipping crate and modified the subframe to fit my 3510 Branson.
I have to remove the 3 pt arms and the subframe attaches to those axle brackets and top link.
In the front I made J bolts to hold the subframe to the FEL brackets.
I don't like leaving the subframe on the tractor because it gives me too little ground clearance.
The subframe is critical to keep from busting the tractor in half.
I have had a hose blow off of a fitting and had to make a couple fittings to fit US hose because my local hydraulics shop could not match up the Chinese fittings.
I also had the round loupe on the end of a cylinder rip out and had to repair that.
/ An "axle-surrounding" type backhoe subframe #8
VERY NICE work so far.
Are you sure you arent BS-ing us about this being your first venture into metal fabrication??
ONly suggestion I can offer: I noticed some of the bolts didnt use lock washers. I would suggest it as you dont want them bolts comming loose. And its cheap insurance. I would use them on every fastner you use.
The bolts in the pictures that don't show lock washers have them at the end adjacent to the nuts. In one picture, there are lock washers at the bolt heads because where wasn't enough clearance to put a lock washer adjacent to the nuts. Is there any value to have a lock washer at both ends?
No BS-ing about this being my first venture. That's why it took me over six months (having to work didn't help either). Thanks for the input.
/ An "axle-surrounding" type backhoe subframe #10
You do some great looking work, I'm impressed! It appears that you put a lot of thought in your planning and attention to detail. Thanks for sharing
044.jpg017.JPGThanks Gunny & LD1.
I wanted to share my experience with bending flat bar and plates. I had to bend the 1/2 x 3 inch flat bar that runs along side the loader subframe to create a 2 inch offset. (see first photo) As I don't have an acetylene torch, I needed to do the bend cold. I searched the web for help determining the force needed, but came up empty. As I don't have a shop press, I made a press using some old lumber from a defunct swing set and a 4 ton bottle jack. It creaked a lot, but held up. The press is not very pretty (second photo), but it worked. As the ends of press have openings, I can use any length of flat bar. Later in the project I had to bend 9 inch by 1/2 inch plate. The bends had to be much closer together than the bends in the 3 inch bar. When I get to that part of the project, I'll show the press I had to build and the forces involved.
The wood in the last photo was charred by my plasma cutter. Plasma cutting on a wood bench is probably not the smart thing I've ever done.
/ An "axle-surrounding" type backhoe subframe #12
The vertical plate is 5/8 inch steel.View attachment 289401
That looks great, LEN!
That's one hefty piece of steel....did you cut it yourself with your plasma cutter? Nice.
Do you have pix of the backets on the hoe and how they attach to this part of the subframe?
On a side note, this photo is just the right size; most of your others are so big I can not easily
view them with my browser. Some browsers may automatically shrink them for viewing; mine does
not. I shrink all my posted photos to about 1000 pixels in the largest dimension (about 100KB file
size JPG files). You can do this with free editors, like what came with your computor, or I use a
cheap editor (Adobe Photoshop Elements) that does more stuff.
Thanks Dave for your your posts. As I said in my initial post the information you have provided has been invaluable.
I did cut the brakets with a plasma cutter (Longevity ForceCut 50i). The rest of the steel (mostly 1/2 inch) I cut with a 4 inch angle grinder. Because of my inexperience with the plasma cutter, the cuts were fairly crude and I was spending too much time cleaning them up with the grinder.
Going forward I will shrink the photos.
The following photo show the parts that permanently attach to the backhoe. It will connect at 4 points. Originally I was planning to weld 1 1/4 inch rods at the bottom of the backhoe brackets, but was concerned about the strength of the welds. Instead I bolted on Cat. 2 to Cat. 3 lower link pins. These pins are 1 7/16 inch diameter. The upper links were suppose to be pins, but after reading your posts I changed to 1 1/4 inch bolts. The picture below shows the finished parts laid out.
The next series of pictures show how the connection is made.
267 - Copy.JPGThe new subframe moves the backhoe 20 inches closer to the tractor as compared to when it was mounted to the 3 point hitch. If the PTO mounted pump wasn't in the way, I could have mounted it another 10 inches closer.
/ An "axle-surrounding" type backhoe subframe #15
That's a good idea, esp since you are using cantilevered pins (supported on one side only). 3-pt
pins are very strong.
/ An "axle-surrounding" type backhoe subframe #16
Nice. Have you noticed how much better the tractor drives now? And how much
more clearance you have at the rear (departure angle)?
Sorry you could not get it closer. I know those Chinese tractors don't put out a lot
of flow/pressure from their own pumps.
Job well done.
The most significant improvement I've noticed is how much better the backhoe handles. Now that the backhoe has a rigid attachment to the tractor, there is a lot more weight on the outriggers when they are deployed. This is especially helpful when pulling out stumps. When the backhoe was attached by the 3 point hitch, it was much easier to drag the tractor as only the weight of the backhoe was on the outriggers.
/ An "axle-surrounding" type backhoe subframe #18
Oh, LEN, that's bad. Three point hitch setups for backhoe attachments come with a
bar to lock the 3PH into one position so it does not float. If it floats, as yours did, then
the whole hoe can suddenly rise and pinch you in a bad position. That can happen
in certain digging situations.
A correct 3PH installation of a hoe will result in the outriggers supporting the whole
rear of the tractor.
In an earlier post, I showed a home made shop press used for bending 3 inch x 1/2 flat bar. Later in the project I had to bend 9x1/2 inch plate to creat a 1 inch offset. These bends were much closer to each other, as compared to the bends in the 3 inch plate, requring a lot more force. I made a heftier press and used a 20 ton jack. Although I used much larger timbers and more lag bolts, it wasn't strong enough. I had to reinforce it with angle iron (left over from the tractor crates). The press worked, but some of the wood slit and the bolts bent (see 2nd photo). Each beam in the press was made up of smaller beams. They were tied together by only a few lag bolts. If I did a better job tying them together, its flexural strength would have increased significantly as they would have acted as a single unit. This was a temporary press that I've already taken apart. Once I have a larger shop, I've like to build a larger version using plywood and flitch plates.
On the subframe, the 3x1/2 inch plate runs along the loader subframe, which is a rectangular tube. They're attached together at the bellhousing in front and again in the rear. I didn't want to bolt them together as I thought drilling holes through the loader subframe might weaken it. I wanted to use u-bolts, but couldn't find the right size. Instead I sandwiched them together using 2 plates and 4 bolts. This should help to increase its flexural strength.
I bought the tractor, backhoe, and loader as a package. It was crated and came with no instructions or a bar to lock the 3PH. I only had a few pictures to help and no experience with tractors. In fact the pictures weren't always correct. I dead headed the first hydraulic pumped as the picture (from the factory!) was mislabeled. The notation at the top of the attached picture was mine in case someone sees this picture out of context of this thread. The second pictures shows the consequence.
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
2022 EZ-GO ELITE...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
2015 RAM 4500 HD 4x4 Service Truck (A62613)
2015 RAM 4500 HD...
Snap-On Southern Thunder Edition 24-drawer tool box (A63689)
Snap-On Southern...
