hst boots
/ hst boots #1
oldtommyboy
Etters,Pa.
BX25
Hello everyone,quick question- I made a plate to protect my hst fan and dang if I didnt get the front boot ripped off instead.
Does anyone know of a replacement split boot so I dont have to remove the propeller shaft on this bx25?
Kubota's boot is 2 dollars and some cents but I do know about the pain in the *** procedure to get the shaft out so is there an aftermarket split boot somewhere?
Concerns,ideas,etc.Thankyou
/ hst boots
Wow,163 views and nothing,oh well guess i know where that leaves me !
/ hst boots #3
I don't know about the split boot but welcome to TBN.
/ hst boots #6
Try an internet search. I am guessing no, because a split boot means a spot that woild leak and let crud in.
/ hst boots #7
Welcome to TBN, I would help you if I could, but unfortunately I cannot. I have never seen this come up before on the forum.
James K0UA
/ hst boots #8
How about some Gorilla tape or electrical tape to help until you get it resolved.
/ hst boots #9
You can buy some liquid rubber that will probably make an effective repair. Make sure you clean the seam very well, using whatever the recommended solvent/cleaner is. If you want to, and can find access, you might consider using the equivalent of a tire patch on the inside of the seam as well. This would provide more strength. The liquid rubber cure rate will be a function of temperature, so you may want to do it in a heated garage, or use a hair dryer. Good luck! Let us know how it turns out.
Phil
/ hst boots
I found the boot laying on top my mower deck when I took it off last week,its destroyed,dont know how or when-thinking when I was munching leaves this fall-no clue. I know you used to be able to but them for car cv joints.
Fiqures,I built a plate to protect the fan and I do this somehow.Yep totally destroyed,only about half is left,looks like a animal chewed it up but no way ( in my garage )
Didnt think about just taping up around it,really dont want to tear this apart,got enough things to do with winter coming.
/ hst boots
I have no idea,you can bet next spring I'll be taking a close look when I put the mower deck back on,I'm thinking it just came from massive amount of leaves that I munched up. I did do a lot of burning brush piles this summer,had to cut down about 50 trees this year and did use the fel to keep pushing the pile together,very possible that I got branches up there too,all this with the mower deck on. When i have the deck on I dont use the plate I made,only put that on in the winter to protect the fan from chunks of frozen snow. I fiqured the deck protects the fan unless I'm really going nuts in the brush but am very careful of branches getting anywhere near the underbelly. So basicly havent a clue,especially scince this hasnt happened to other people.
/ hst boots #13
Some thoughts;
You need a friendly auto parts store that carries the split boots for front wheel drive cars.
Arm yourself with measurements (major and minor diameters and length).
For sure there has to be something that will fit, all it will take is patience and a willing clerk.
Last option; an old inner tube wrapped, say 2 X and couple of screw hose clamps 'til you can get the proper boot, you do want to keep the crap out.
/ hst boots
piloon-yeah,been thinking something like that,was checking online-site named " thecvman " gonna have to get under and take some measurements,I have an outside caliber that will make short work of the measurements then the hard part,trying to match one up.
Also thought about wrapping rubber around it but not sure if the clamps will hit while turning,even thought about buying one from bota for 2.50 and cutting it,then contact cement.
****,aint it a *****,one way or the other is going to be a pain in the ***. Love the bota though!!!
/ hst boots #15
Spray on rubber coating. The kind used to protect tools. It comes in a can to dip tool handles and spray on. If there is a part that moves just put electrical tape on the joint then spray.
/ hst boots
Just want to apoligize for the swear words,thanks for editing.
Hmmm,have to think about the rubber spray,know what your talking about though,not sure about spraying around the exposed bearing though.
/ hst boots #17
I noticed my front boot was torn during a fan belt replacement. This BX has only 52 hours on it and there has been no time when we drove it over something that would have gotten up there and torn it. I noticed that the rubber is very thin where the tear occurred. My fix was some black RTV for now. The boot itself is only 4 bucks from Kubota but the hassle to get the driveshaft out is a whole different story. :eek:
/ hst boots #18
I just got through replacing both drive line boots on my BX23. After looking at it for a while, I found that I didn't need to remove the fenders or the ROPS. By unbolting the floor pan from the fenders, and some careful manipulation, was able remove the floor pan to get to the drive shaft Removal of 5 bolts and I had the shaft in hand. Replacing the boots was a simple process of removing a couple of snap rings, and removing the CV joints. With the drive shaft out, replacing the fan would have taken an additional 5 minutes. The total job took me about two hours at a leisurely pace.
I guess I don't understand why Kubota would make this task so difficult in later models.
Preliminary Listing / Full Catalog Coming Soon! (A62177)
Preliminary...
2005 Isuzu NQR 4 door box truck with folding gate (A63118)
2005 Isuzu NQR 4...
Deere 35G (A62180)
Deere 35G (A62180)
2023 CATERPILLAR 150 AWD MOTORGRADER (A63276)
2023 CATERPILLAR...
PORTABLE SAND BLASTER (A62131)
PORTABLE SAND...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
