Global Warming?
Status
Not open for further replies.
   / Global Warming? #2,771
If C02 were the only enemy, it could be rather easily controlled by planting unused open lands in fast growing, high exchange rate plants, duckweed, many grasses and some trees.
   / Global Warming? #2,772
HS, I too would be interested in these devices. Having spent 20 some years in the permitting, regulation and enforcement of regulations regarding Air Quality standards and emissions, it seems odd I haven't heard of these things. Must be fairly new. Amine units have been around for some time, but hooking one up to a coal fired power plant is fairly expensive, not to mention the maintenance required. As for the $10 filter on your car, the last guy I ran into who had something similar was prosecuted for, and found guilty of fraud.
http://greenupgrader.com/3744/synthetic-trees-could-be-environmental-co2-scrubbers/
I'm interested that a professed regulator never thought to invest time and effort to investigate if removing pollution for the air directly might be a better, easer and cheaper way of tacking a problem rather than regulate. Just shows me how narrow minded these regulators are and the lack of interest in really solving the issue but just regulating, what many of us have know from the every start. I have read about many over the years, 2 seconds of search turned up these, it's an old idea. Spending tax dollars to scrub CO2 rather than look to spend billions to get a 1 ton truck to get 55mpg just maybe a better idea. My point is there is no threat, if you assume there is you find the people articulating the threat are not interested in solving it. It's a hoax, get it...Always was.
HS
   / Global Warming? #2,773
HS
We asked you for further information on your $10 miracle filter. Do you have a reference or name?
Some of you keep referring to science or devices that are never referenced. Sounds almost like the old Sen McCarthy trick of waving around a wad of paper that is supposed to be a list of hundreds of commies. He was shown to be a fraud. Where is your information?
   / Global Warming? #2,774
Maybe just older than you and followed the auto industry since the 1960's and pollution control devices on auto's. I have lived all this crap for 50 years. It's obvious to me Mr. IslandTractor with all your intellect you just discovered the other half of the coin. You just don't know what you don't know. You have allot of homework, maybe years or decades worth before you spout this man made global warming thing as some settled science with a bunch of hay seeds holding out, it's you whom didn't even consider or recognize the whole picture. That's ok, many people like you have been fooled, so called educated ones too.
HS
   / Global Warming? #2,775
I'm not sure I get your point; I agree with what you say, but the way I see it, the conflicts that stifle science are between science and the stilted religious community(s). When the church is as powerful or more powerful as the host government, and has it's own courts to punish (or convert, or stone or burn at the stake as the case may be), science has to work undeground or in a more hospitable country. In such a case, dogma wins every time. Admittedly, today science will progress in enlightened areas of the world, but things were a bit slow in the dark ages. It's really scary to think that at one time, you could be executed for theorizing that the earth revolved around the sun, instead of vice versa, simply because any science to the contrary was in opposition to the absolute "truth" as seen by the church.
The Dark Ages? Depends on where you refer to. Timbuktu was once the centre of knowledge and economic power!
Scientist are; well, Scientists. Normal folk one and all. Some just get vetted through more rigorous regime's than other's!
   / Global Warming? #2,776
Dark Ages? You mean when learning and science were preserved by the Irish monasteries? Maybe you mean the period after that when universities that provided the bastion of higher learning were all religious institutions? No? Maybe you mean that great hieratic, Isac Newton? Well, he did say "Gravity explains the motions of the planets, but it cannot explain who set the planets in motion. God governs all things and knows all that is or can be done." Dang! He's not an atheist. So, where does this notion that science and religion are in direct opposition come from?
Randy brings up an important point. If the problem is CO2, Why don't we plant more fast growing CO2 processing plants? The best answer I can think of is because it doesn't end up in the regulation of others behavior. The plants would sequester the carbon, and release the O2. Much better than just pulling it out of the air and burying it.
   / Global Warming? #2,777
My main point is if you really believe in GW, you should spend your time and money building and developing machines and science that remove CO2 from the atmosphere. What you don't do is put regulations in place to destroy your economy and access to cheap energy. Trying to get a one ton truck get 55mpg is stupid. The only reason to destroy the biggest most successful economy on earth through these green agenda is to take power, it has nothing to do with CO2, get it? As for the Senator McCarthy comment, read this...again a product of miss education or propaganda.
Most-hated senator was right
HS
   / Global Warming? #2,779
Synthetic Trees Could Be Environmental CO2 Scrubbers | greenUPGRADER
HS
CO2 regulation is a fairly new phenomenon, and as far as I know, there aren't any final regulations in place. Emission and removal of CO2 was never a regulatory issue until the obama adminstration. It is used in many industrial processes, but not as a regulatory requirement. I would be interested to know how a retired Coastie would presume to know so much about a the mindset of a former regulator whom you know nothing at all about. Oh, FWIW, the apparatus you referenced is still in the prototype stage. Building one of these things, doing pilot plant studies and working out the bugs is another ball game altogether...not to mention the environmental issues connected with putting the stuff down an injection well in the middle of the ocean.
   / Global Warming? #2,780
Are you referring to a small portion of the world?:)
Status
TUGGER TRAILER (A58214)
TUGGER TRAILER...
2018 CATERPILLAR 289D SKID STEER (A52709)
2018 CATERPILLAR...
2015 GENIE Z-62/40 TELESCOPIC/SCISSORING BOOM LIFT (A52709)
2015 GENIE Z-62/40...
Bucket (A55973)
Bucket (A55973)
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
2016 Ford F-150 XLT Pickup Truck, VIN: 1FTEX1EP4GFD61185, Extended Cab, 4 x 4, 2.7 L EcoBoost Gas (A59076)
2016 Ford F-150...
