At Home In The Woods
/ At Home In The Woods #4,401
Salt peter? That is an interesting way to get rid of a woody......
Pun intended...... If you don't understand, then you never were in the Military......LOL
RT
When I was employed by a LEO in the 70's, I had heard rumors in regards to salt peter and decided to do some research. I found documented cases where salt peter was indeed used and given to inmates in Tennessee State Prisons.
/ At Home In The Woods #4,402
ENG18LT,...From your description, I'm not sure how far the transformer will be from your house. You will want that transformer to be as close to your house as possible so you can minimize the length of the expensive 220V lines between the transformer and you house. High voltage primary wire can be smaller than lower voltage lines so you will want the 220V lines to the house be as short as possible...
When we put in power, the power company advised to have the transformer at least 100 feet from the house and further if possible.
Many transformers can hum or buzz, and you want that noise far enough away to not be audible at the house.
We opted for ~150 feet and have never had a problem.
Our transformer is 100 ft from the house, not because of potential buzzing or humming noises. We located the transformer 100 feet from the end of the house so that it would be somewhat out of site when looking at the house. It is common to see transformers sitting in people's front yards but that wasn't our preference.
Obed
The TBN safety inspectors gave me a hard time here when I cleaned my gutters last year.
I recently ordered these ladder levelers Louisville Ladder LP-2300-00 Ladder Leveler for $59.00. They got very good reviews on Amazon. Some of the levellers only extended 8" which probably wouldn't be long be enough for me. The levelers I just ordered extend to 15". The levelers weren't hard to install. I had to drill 8 holes through the ladder and install 8 bolts. The hardest part was trying to drill the holes so that the levelers would not be attached askew.
Maybe this year cleaning my gutters will be a little less like a "circus act".
/ At Home In The Woods #4,405
We don't plan on cutting any of the stuff behind the house other than any trees the excavator contractor damaged. Although it won't be anytime soon, my wife has indicated the desire to clear some of the undergrowth in the natural area in front of the house. It might be nice to get a better view of the house when approaching the house down the driveway. The house is quite obscured when the leaves are on the trees. Right now, the natural area in front of the house has briars, dead stuff, etc. and just looks unkempt. I'd hate to lose the red leaves though.
attachment.php
If you burn that area infront of the house it will clear up a bunch of that undergrowth. Burn the woods every year for a few year then ever other year. It looks surrounded by drive or grass. Id just wait till wind was blowing toward the street and back it into the wind.
Just cause a tree has red leaves this year does not mean they will always be red. Some hickory or maple will vary in reds to yellow, depending upon nature and that specific tree.
As far as stumps and damaging tires. As long as you cut it flush to the ground you wont damage a tire on anything even your car. I have cut plenty of trails in the woods and never removed a stump, trees with stumps up to 8"s or so usually are flat with the ground, its usually the trees starting at 12" stumps and up that are mounded up around them as they press the dirt out n up as they displace it to grow, these will end up with a mound, but i still cut as low as i can without getting in the dirt and drive my trucks right over them, a tractor tire will not be dameged by a flush cut stump ever.
/ At Home In The Woods #4,406
Obed, The transformer is going to be 320' off the road and 90' from the house off the side of the driveway. I have to dig the trench, buy the conduit and primary cable, install it myself, buy and set the transformer base, and set up the meter pedestal close to the transformer. All of which is not included in the $8k verbal quote from the power company.
Thank you for your response.
Lee
/ At Home In The Woods #4,407
Lee
Are you certain that you have to buy the high voltage primary cable? I forked over 13k for a similar deal but they will provide the primary, secondary cable, and transformer pad. Where do they expect you to buy this stuff at?
Lee
Lee,
I have to wonder what the justification is for charging you $8K? I would tell them that I am considering building the house right beside the road and ask them how much that would cost? When you find that the price is almost nothing beside the road, I would ask them what the $8K is for if you are paying for all the materials and labor. Something doesn't seem to add up.
Obed
/ At Home In The Woods #4,409
View attachment 287793View attachment 287794
A ladder stabilizer, if you don't have one, is a good safety item too. Aluminum Stabilizer-AC96 at The Home Depot
If you can get the angle correct, the stabilizer ends will rest on the roof allowing the ladder to bridge the gutter. The ladder will also be much less likely to want to slide left or right.
My dad burns the woods on his farm every year or so, or at least he used to. I don't know if he has done it recently. I could probably clear out the junk in the woods in front of our house in a weekend or less with a sling, loppers, chainsaw, and tractor when I feel like doing it. Although I probably wouldn't catch our woods on fire, I don't think I want to chance setting that natural area on fire.
Obed
/ At Home In The Woods #4,411
Wouldn't solar become a viable option at this point? Live off grid and not have a monthly usage bill?
/ At Home In The Woods #4,412
Lee,
Obed
My thoughts as well, unfortunately that's the way it is with this particular power company. I did verify this with several local electricians before I shelled out the cash for the wire.
Thanks again
Lee
/ At Home In The Woods #4,413
Obed
If you read up a bit and watch videos im sure on youtube and follow your forestry commission burn page it will tell you good days to burn. On those days you have high enough humidity you almost have to force it to burn!. I am lazy though i would make sure there is a break around it and light it up. You should not have flames ever much higher than your head which do nothing to the woods but consume litter and kill small harwood and briers on the top.
Its not like your burning when you havent had rain in 6 weeks and there is 15% humidity or anything.
I have helped in quite a bit of burning. Done right its actually beneficial to the woods and makes it look better in the long run.
/ At Home In The Woods #4,414
I thought the power company had to provide you power? We are two miles in on the farm, and there already was a power pole line coming to a side of the property.....I wanted it underground for ascetics , but they SCE&G provided the underground wire, and charged me a reasonable amount of money for it, and I had to dig the ditch for them to bury it in......They were very nice to work with.....This is rural so everyone knows everyone else...I know times have changed but this was as it use to be.....Tony
/ At Home In The Woods #4,415
Man Clemson---This is his home, yes the same one he has worked so hard for ...Who would want to see blackened trunks against the pure white snow.....Poor suggestion....Tony PS we have to burn , due to the size of the place, and it takes years for it to not look horrible....
Our local power company was also great to work with. In fact, all the utility companies, except for Comcast Cable, were very helpful while we built the house.
/ At Home In The Woods #4,417
Moneywise, it probably would have been the smart thing to do. I'm at a point in my life where I want to turn on a switch and not worry about how much power I can use or add another maintainance item to my already bloated list.
/ At Home In The Woods #4,418
To each his own, i think woods look great that are burned. The fire scars are minimal if you do it right. Its not like your going to have 4-15ft char marks on the trees!! Thats a wild fire. You will have charring up to say 2ft in the hottest places most of it in hardwood will be 12"s or less and fall off by the end of the summer. You really only see it in the crevices in the bark and cankers.
If you cant stand any char on your trees DO NOT BURN. But if you like the woods as nature intended that will include some charred bark. Before the white man started putting out fires i think his area was on a 5-10 year burn cycle, naturally.
Dave,
I bought a ladder stabilizer last year. Combining the stabilizer with the levelers should make my gutter cleaning about as good as it will get.
Obed
Yesterday I had the day off from my regular job. After returning home from the fireplace store, I cleaned out the 2 story gutter. I attached the Louisville Ladders stabilizer to my ladder without any trouble. The stabilizer made the ladder much more steady. I still didn't like climbing that high but there's not much I can do about that part of the job. I can probably put up with cleaning the gutters 2 or 3 times a year. Having the ladder stabilizer really helps.
I raked up the leaves that came out of the gutters and removed them.
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
2017 New Holland T4.110 Cab 4WD w/ 655TL Loader – 1,619 hrs – Excellent Condition
2017 New Holland...
2017 JOHN DEERE 333G (A60736)
2017 JOHN DEERE...
KUBOTA RTV 900 UTV (A62130)
KUBOTA RTV 900 UTV...
1981 LINK BELT HSP 8028 (A58216)
1981 LINK BELT HSP...
2014 International DuraStar 4400 Service Truck with Crane, VIN # 3HAMKAAN0EL771639 (A61165)
2014 International...
