Welder Power Charts
/ Welder Power Charts #1
Beltzington
Appling, Georgia
JD 3720
Could someone help me understand these ratings? I am specifically interested in the input current requirements for 100% duty-cycle (200A) Here is the OEM specs. TIA
http://www.lincolnelectric.com/assets/en_US/Products/K2269-1/e2161.pdf
Input Power
Voltage/Phase/Hertz
208/230/460/575/3/60
Rated Output
Current/Voltage/Duty Cycle
275A/31V/35%
250A/30V/60%
200A/28V/100%
Input Current
@ Rated Output
38/37/19/16A
34/33/17/14A
27/25/13/11A
/ Welder Power Charts #2
For the 100% duty cycle @ 200A, input current depends on what voltage you are supplying the welder with and are as follows:
208v = 27a
230v = 25a
460v = 13a
575v = 11a
But you DO realize ALL of them numbers are for 3-phase power right??
If you want 100% @200A on SINGLE PHASE, they are as follows
208v = 49a
230v = 48a
460v = 26a
575v = 21a
I do, not only was I mentaly challenged this morning and just couldn't seem to connect the dots, I also was having issues cutn and pastn. Thanks very clearing this up for me LD1, you are a "super member," excepting that orange tractor in your avator :)
Have a great week!
/ Welder Power Charts #4
I'm not an electrician, but will a 3phase machine work on single phase without a phase converter but just use more current? I was always of the impression that a 3 phase machine wouldnt work on single phase current at all.
/ Welder Power Charts #5
depends on the machine. some can be set up for either.
/ Welder Power Charts #6
Have a great week!
No problem at all.
PS: if you had an orange tractor, you probabally wouldnt need the welder to have to fix it all the time:laughing:
Bingo. The welder in question can be set up for either 3ph or single. Most of the new inverter style welders are this way. But they do require more current given the same voltage though. If you notice 230v 3ph only needs 25a but 230v single phase needs 48a
2015 CHEVROLET CAPRICE (A66091)
2015 CHEVROLET...
Unused 2023 Monroe-Tufline DS1144T 12ft. Hydraulic Box Scraper Tractor Attachment (A66734)
Unused 2023...
2005 PETERBILT 379 (A67714)
2005 PETERBILT 379...
2009 CHEVROLET IMPALA 4 DOOR CAR (A66091)
2009 CHEVROLET...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2020 INTERNATIONAL MV607 REEFER (A67714)
2020 INTERNATIONAL...
