Backhoe Backhoe Bucket Backwards, Can you?
/ Backhoe Bucket Backwards, Can you? #1
OrangeBeast
Northwestern Vermont
Kubota BX22
Ok I know this is a strange question but can you install a BT600 bucket flipped 180? and it be functional?
/ Backhoe Bucket Backwards, Can you? #2
I am trying to work on this one but you are really making my brain hurt. :)
/ Backhoe Bucket Backwards, Can you? #3
I know you can turn the bucket around on many trackhoes with quick attach hitches on them.
/ Backhoe Bucket Backwards, Can you? #4
Why? Could you even empty it when filled? It dosent have a clam like a shovel! Now I wanna go try!
/ Backhoe Bucket Backwards, Can you? #5
Have you tried it? Does your setup allow it eithout modification? I understand why you want it to work. Are you trying to dig a wall and the depth wont allow you to dig from the top side?
/ Backhoe Bucket Backwards, Can you? #6
Like this video I found.
Ya like that but on a BX kinda scale.
I am working on adding buttress supports to a foundation that is only basically on grade! What the original owner was thinking who the heck knows. So over the summer I had no problem digging the 4' down in the clay but I was having difficulty getting under. And wow is it hard to do with a shovel. Right now I dont have the BH on as I am about to set up the tractor for winter. This just popped into my head so I wanted to see if anyone tried this but a search came up with all kinds of BH stuff but did not see anything on flipping the bucket around and using it that way. I know its not designed for it, but its was a thought, and it would not be to do the entire hole just finish it up. I have 2 done and I have 8 to do next summer and frankly any way to make it easier i'm all for it.
I don't mean to make anyone's head hurt or explode on thinking about this.
/ Backhoe Bucket Backwards, Can you? #8
Like i said, can you get your setup to do it? If you can, than do it. Your not gonna hurt anything. Just do it if you want. Seen it done a handful of times to dig lower walls. Its not something out odf the ordinary
/ Backhoe Bucket Backwards, Can you? #9
Shortthrow 50,I find your avatar and other picture to be very offensive and childish.I am surprised it is allowed.This forum is supposed to be about tractors.
/ Backhoe Bucket Backwards, Can you? #10
I don't know but I wonder if the hydraulics and boom are designed for working in that direction. But for gentle use it might be okay.
Now back when I was a kid, that's the way the power shovels worked (they ran off of cables not hydraulics, and had trap doors in the bottom for dumping.)
Ken
/ Backhoe Bucket Backwards, Can you? #11
I tried it with my 1026r and it didn't fit. I may modify it to make it happen someday. The ears weren't tall enough to clear the dipper and allow the pin to slide in the hole.
That's what I was wondering about!
/ Backhoe Bucket Backwards, Can you? #13
I don't give a rip about shortthrow50's politics, and I'll wager they don't care about mine. The President and the Governor probably have pretty thick skins, but how do you think that stuff makes their families feel? Their kids? And what in the world does it have to do with politics, let alone tractors.
Mods, how about cleaning this up.
Thanks,
Z.
/ Backhoe Bucket Backwards, Can you? #14
Swick1 Thanks for sharing your pics. I see you have a JD. So how different is your BH to my BT600 BH? I may just have to put mine back on and have a look for myself. Its not the end of the world it it does not work. Would be cool if it does tho. Weather is getting cold now here and I don't see myself having any time in the next week and a half to try either.
/ Backhoe Bucket Backwards, Can you? #16
I really wanted to do this on my kubota b2920, haven't figured it out yet, if you do send picks. Itd be great for transplanting
/ Backhoe Bucket Backwards, Can you? #18
I agree...racist much?
/ Backhoe Bucket Backwards, Can you? #19
I also find it to be offensive
to animals.
/ Backhoe Bucket Backwards, Can you? #20
I don't know how similar they are but you could have new tabs put on fairly easily. I want to build a set when I get some time.
Tan Jet Dock Drive-On (A59228)
Tan Jet Dock...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A63118)
2023 Top Air ATV...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
2014 John Deere Z930M Zero Turn (A63116)
2014 John Deere...
KUBOTA BX23SLB-R-1 TRACTOR (A62129)
KUBOTA BX23SLB-R-1...
2017 CHEVEROLET 550 HD LCF S/A 4X2 24FT BOX TRUCK (A59910)
2017 CHEVEROLET...
