Is this a hint ?
/ Is this a hint ? #1
E/S
Gold Member
Reno, NV
Kubota M8540HDC12-1 4x4 w/ Cab
The wife has started running the M85 and I caught her doing this today.
I think she may want her own tractor.
E/S
/ Is this a hint ? #2
Think she needs a bigger trailer/wagon to tow behind the tractor! If you don't like sharing maybe an RTV is more in order.
/ Is this a hint ? #3
Lawn mower should be right size for that double axle trailer ;-) cab or no cab is the 63'000 $ question, He He
/ Is this a hint ? #4
Funny! I think she should carry the trailer in the bucket. Looks like a scut or cut would fit here.
/ Is this a hint ? #6
Maybe a bigger tractor to pull that heavy wagon?
/ Is this a hint ? #7
At least she had enough tractor to control the trailor load when going down a steep grade.:). A .B series tractor or an ATV would use a lot less fuel though. Let it be HER idea or you will never get her out of the M85 and you will be driveing the CUT.
/ Is this a hint ?
I think I will get her a dump trailer ( her idea ) and share the tractor. I really can't afford / justify another tractor.
E/S
/ Is this a hint ? #11
Ironic! Time to call barlows for a BX.
Sent from my andriod using TractorByNet
/ Is this a hint ? #13
My wife drivers "her" BX and "our" 5740, but won't go near "my" M8540...
/ Is this a hint ?
The only time any piece of equipment ( or kids ) are " mine " is when there broken. She likes the M85 better than the old 245 DT we use to have.
E/S
/ Is this a hint ? #16
E/S
Funny how that works.:laughing:
I think she would like the M8540 if I can ever find the time to teach her to drive it. We took the pull type rotary cutter off for the winter, so this may be a good time to let her learn how to operate it. She has back problems and had to quit using anything with a foot clutch which our CX80 had, but with the hydraulic shuttle, she should be able to do OK and the foot clutch is a LOT easier to use than the one on our Case too.
/ Is this a hint ? #17
Hey TripleR, do you ever use the clutch on your 8540? I was wondering because I only use the (9540) clutch when inching the loader into a pile or backing to hook up. Don't know how everyone else does it.
/ Is this a hint ? #18
I had a heck of a time breaking myself from using the foot clutch when we first bought it as I had 12 years on our Case CX80 with synchro shuttle, but finally got use to it. It sounds like we use ours about the same as it seems as though I have a little more precise control with the foot clutch. For everything else I use the clutch on the column.
/ Is this a hint ? #19
Does that include changing gear while moving?
/ Is this a hint ? #20
Yes, for the most part, I still forget and use the foot clutch from time to time, but rarely. My left leg is partially paralyzed and I have had to clutch with my right foot for years, so the hydraulic shuttle shift is really nice. You should have seen me on our CX80 backing a 10' pull type rotary cutter down a steep slope to mow next to the pond, or worse running back and forth across the levy with the pond on one side and drop off on the other; talk about a flurry of activity in that cab.:laughing:
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63118)
2017 Cadillac...
2017 PETERBILT 389(INOPERABLE) (A63569)
2017 PETERBILT...
2021 CAM p4EC16W102 16ft. 7000lb Utility Trailer (A64047)
2021 CAM...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2006 Hitch and Trailers Inc. 12ft S/A Utility Trailer (A61574)
2006 Hitch and...
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
