Lilredfox sending out SOS
/ Lilredfox sending out SOS
7H15 M3554G3
53RV35 7O PR0V3
H0W 0UR M1ND5 C4N
D0 4M4Z1NG 7H1NG5!
1MPR3551V3 7H1NG5!
1N 7H3 B3G1NN1NG
17 WA5 H4RD BU7
N0W, 0N 7H15 LIN3
Y0UR M1ND 1S
R34D1NG 17
4U70M471C4LLY
W17H 0U7 3V3N
7H1NK1NG 4B0U7 17,
B3 PROUD! 0NLY
C3R741N P30PL3 C4N
R3AD 7H15.
PL3453 F0RW4RD 1F
U C4N R34D 7H15.
:chillpill::chillpill:
Look, I'm OK with honest spelling and grammatical errors. But to intentionally botch, no, butcher the english language is neither cute nor endearing. Not that I'm the TBN police, nor would I want there to be, but this is over the top ridiculous and childish.
/ Lilredfox sending out SOS #122
7H15 M3554G3
53RV35 7O PR0V3
H0W 0UR M1ND5 C4N
D0 4M4Z1NG 7H1NG5!
1MPR3551V3 7H1NG5!
1N 7H3 B3G1NN1NG
17 WA5 H4RD BU7
N0W, 0N 7H15 LIN3
Y0UR M1ND 1S
R34D1NG 17
4U70M471C4LLY
W17H 0U7 3V3N
7H1NK1NG 4B0U7 17,
B3 PROUD! 0NLY
C3R741N P30PL3 C4N
R3AD 7H15.
PL3453 F0RW4RD 1F
U C4N R34D 7H15.
Must be space talk!
/ Lilredfox sending out SOS #123
From Huck Finn: “Yo' ole father doan' know yit what he's a-gwyne to do. Sometimes he spec he'll go 'way, en den agin he spec he'll stay. De bes' way is to res' easy en let de ole man take his own way. Dey's two angels hoverin' roun' 'bout him.” The reason for this is obvious in conveying the characters speech pattern and flavor of the time.
In normal day to day writing, the intent is to communicate, when one strays from commonly used words, spelling, grammar etc., one runs the risk of failing to be fully understood by others. Such writing appears to be an affectation and I do have trouble reading and understanding it.
Just a random observation that came to me after reading this.
/ Lilredfox sending out SOS #124
Exactly.
/ Lilredfox sending out SOS #125
From Huck Finn: 添o' ole father doan' know yit what he's a-gwyne to do. Sometimes he spec he'll go 'way, en den agin he spec he'll stay. De bes' way is to res' easy en let de ole man take his own way. Dey's two angels hoverin' roun' 'bout him. The reason for this is obvious in conveying the characters speech pattern and flavor of the time.
Exactly.
/ Lilredfox sending out SOS #126
Hi Lil Red
Looks like you have a severe water contamination problem. Is there anywere rain water is coming in,like a shifter boot or top plate cover with a bad gasket.
After cleaning screen and bottom of the housing out refill with new fluid, add 1/2 a bottle of isopropyl alcohol to the system to dry it out, run it for 15 min
or until filter plugs up, drain and refill with clean fluid. If you can park it in a shed or tarp it to keep it dry, that may help if you have a leak.
Send a picture of the fluid you drain next time. If you are still getting debris in fluid, try filtering it through an automtive type paint filter.
Did you get the fuel tank cleaned out, do not run without a fuel filter, injector pumps dont like debris or water.
Dave
/ Lilredfox sending out SOS #127
lilred,
Your next step should be inspection of lift piston mechanism. It'll take 1 hr max and $10 cost to replace the nylon seal. I have sent you links and suggestions to correct. Have not heard feed back if you read them all or done some of the suggestions. You can abandon this thread and just follow the links and I'm confident you'll find all you need for a complete repair. You do not want to destroy you injector pump or the hyd pump, if you do so then that tractor would be scarp metal at best.
I have a link here for you that show how to replace injector pump oil that is separate from crankcase
JC,
good luck.
http://www.tractorbynet.com/forums/...-pump.html?highlight=ford+1700+injection+pump
/ Lilredfox sending out SOS #128
i recieved that same email about a year ago. it says
this message,
servers to prove
how our minds can
do amazing things:
Impressive things!
in the beginning
it was hard but
now it ???? like
your mind is
reading it
automatically,
without even
thinking about it,
be proud! only
certain people can
read this.
7H15 M3554G3
53RV35 7O PR0V3
H0W 0UR M1ND5 C4N
D0 4M4Z1NG 7H1NG5!
1MPR3551V3 7H1NG5!
1N 7H3 B3G1NN1NG
17 WA5 H4RD BU7
N0W, 0N 7H15 LIN3
Y0UR M1ND 1S
R34D1NG 17
4U70M471C4LLY
W17H 0U7 3V3N
7H1NK1NG 4B0U7 17,
B3 PROUD! 0NLY
C3R741N P30PL3 C4N
R3AD 7H15.
PL3453 F0RW4RD 1F
U C4N R34D 7H15.
i cant thank you enough jc. you've given me alot to absorb here. i no i'll have some questions as i go. it's been a blessed challenge learning the components of the tractor and what all and how they all work. shouldnt take but another few days to finish wiring this house im doin. then i can spend all the times it's gunna take til i get this tractor RIGHT!! im still tryin to git all the crud out of it. it's lookin and acting like they really did stuff TP down inside it and water it down. like i sed. wen i first got the tractor back. i drained out pert neer 9 gals. perhaps on a wing and a prayer. but by golly, i'll get there.
TBN has a great wealth of men. wich i just so happen to need now n again.
lilred,
JC,
good luck.
/ Lilredfox sending out SOS #130
Wow this has gotta be the most active new member post! Welcome to tbn lilredfox, reading your post with all its colloquialisms has been great, stretched my feeble brain a bit(maybe not a bad thing)trying to understand a few things but mostly gave me lotsa chuckles. My second favorite thing about traveling is hearing all the local versions of the english language and since we have such a large membership from all over it is nice to see the posts reveal regional dialects.
Is this you?
/ Lilredfox sending out SOS #131
Cool Lilred:thumbsup: let me know if you get in a pickle here or thru pm . The most important quality is sheer desire and perseverance. I think you got some of both:)
JC,
/ Lilredfox sending out SOS #132
update to bold is below
this message,
servers to prove
how our minds can
do amazing things:
Impressive things!
in the beginning
it was hard but
now it ???? like (on this line)
your mind is
reading it
automatically,
without even
thinking about it,
be proud! only
certain people can
read this.
/ Lilredfox sending out SOS #133
Is this you?
Great photo...but can't be lilredfox....she's not to be found a-sittin' on her tail, nor looking scaredy-like...
I GOD IT
We all hav a place
in this wirld it is sed
sum er tha leaders
sum er tha led
we r all parts
of a mighty machine
tiny gearz
n tha pieces unseen
Consider ur watch
wich part wood u choose
Az tha most nessasary
tha springz or tha screwz
The hands or the pins
large cog or tha small
Wich makes it tick
Wich part most of all
Consider ur tractor
It wont go without wheelz
the battery, the tires
tha spark plugs,
tha wires
Remove the brakes
the steerin wheel
the clutch
wood it then
be wirth half as much
The greatest gear couldnt
Spin without grease
n it's held in its place
by one Simple piece,
So, dont be dismayed
when you seem in a
Rut,
Ur just as important if only
A nut
lilredfox
/ Lilredfox sending out SOS #135
Reply with a rhyme
because if you do
some of us 'll get it
before others do
Red has lots of fun
that's all I can say
But I do admit
She's made my day
Man/wo-man, She/He,
theres more than
just 2 a me
wudda thrill,
yea finally find
sumwunz thats real
this lilredfox
is not scared
nor will she run
not wen these guys
are more than fun
Is this you?
AWWWWH. that hit wunna my spots fur sure. glad u god it. n ta think. it's just startin ta warm up fur the winter. tungularafishcamp has made a wish. just sit back n we'll have our own trick or treaters live here on TBN.
Reply with a rhyme
because if you do
before others do
Red has lots of fun
But I do admit
She's made my day
this wut looks ta be a mixtured mess with molasis *** out of my oil bath.
i bet ol blue breaths much bedder now...
in all my day of tinkerin. ive never seen nuthin of the sort.
/ Lilredfox sending out SOS #139
wow, pretty nasty looking stuff but imagine if you did not have the filter and all of that would end up in combustion chamber. Filter did what it was supposed to do. Oil bath filter is one of the simplest and best design that lasts for ever. I'd just soak it in diesel well and use a wire brush to clean all the way to the metal. Fill the bowl with good clean oil and you're good to go. This tractor of yours did not get any TLC.
JC,
my Pa luved ol blu. It did not lack TLC. not from him it didnt. he got that tractor off his best frend that passed while back. he wuz a fanatic about maintance on machinery. n thats prolly wuts savin it. it wuz the cuzzin that did all this damage. sed if he cant have it nobody can. they chained the boxblade to the top of the brush hog n the teeth pierced clean thru the top. drove it a ways like that. wen i got on it popped a wheelie takin off. it wuz the wrong bushhog anyways. they kept my good wun. my pa passed a yr ago taday. i pray he haunts the H.E. duble L ryt out of them tanite. serve em ryt.
they had that tractor for 6 months too. so who no's wut all they did to it. wutever it is. with the guidance of TBN, i'll git thru it.
JC,
