Grapple hook ups
/ Grapple hook ups #1
johnbarker
Bainbridge
5010 mahandria
I have a mahindra 5010 with a FEL and I want to hook up a grapple my dearler tryed to sell me a valve setup that would kill the FEL when I was open/closeing grapple, I want to be able to have full use of FEL and grapple at the same time, I relize that it will operate at a slower pace when grapple is in use that ok. first my grapple has 2 cylinders, I was thinking of tying into the hose for FEL where it comes out of hydralic port by adding a 12 volt valve and letting it it return fluid where the FEL dose by tyeing in there too. I want to add a swith onto my joy stick so it will be a one hand operation. I have listed a valve below for surplus center its only a 5GPM valve but i belive this should work. I have looked on here for joy sticks with no luck as to where to purchase one with a switch built into it can someone please point me in the right direction
Thanks John :)
https://www.surpluscenter.com/item.asp?item=9-7989&catname=hydraulic
/ Grapple hook ups #2
What your dealer suggested is called a "diverter". There are LOTS of threads here if you search that term. You only loose the dump/curl while your controlling the grapple, its a great cost-effective way to do it.
For independent control, you will need whats refereed to here as a "true 3rd function" valve, or a solenoid spool valve. Again, LOTS of threads, search the word "grapple" here in the hydraulics forum for hours of reading.
The valve you linked will not work. And if by "tyeing" in you mean to add Tee's that won't work either, all valves must be added in series.
WR Long makes kits to do exactly what you want: Valve Kits
Again, there are hundreds of threads on this very subject...
/ Grapple hook ups #3
You can operate two valves at the same time only if the first valve in series allows some fluid to pass through.
Full application of the first valve lever will use all the fluid the pumps out and the cyl output goes to tank.
/ Grapple hook ups #4
I only see the 3rd function as being useful for very delicate work where you need grapple and curl. I don't think the tractor is the right tool for that. Either setup is fine but remember you aren't going to run a hydraulic saw or bush hog from your tractor's stock hydraulics which is the only reason I think you would want all 3 functions available.
/ Grapple hook ups
All i want to do is be able to is curl and grapple at the same time, JJ I would tye into hose where it leaves pressure side of sump before the first FEL valve I think this should work like i posted it will slow down FEL during grappling but thats ok.
((Next question dose the FEL valve let the fluid pass thur back to sump untill the joy stick is activated if so then my ideal is over:thumbsup: this just hit me I was thinking about rear hydralics and they spring back to netural to keep from getting hot I dont know if FEL valve dose this or not and the FELis a factory installed one.
/ Grapple hook ups #6
If you feather the loader or use half lever. then the 3ed function will work dividing the fluid between them.
In a open center hyd system, the fluid flows through all valves with levers in neutral. If a valve is being used, the cyl fluid will go to tank.
/ Grapple hook ups #7
The valve you have listed 9-7989 is a closed center valve the same valve with an open center is #9-7987.
/ Grapple hook ups #8
johnbarker ,
Yes, loader/FEL valves are spring center and will return to center, except when you go into float.
Again, you can use both valves at the same time if you don't use all the fluid for the loader/FEL.
All valves in an open center should be in a series configuration. So from your PB port of the FEL, run a hose to the IN port of the 3ed function valve, and the OUT port will go to next valve in series.
https://www.surpluscenter.com/item.asp?catname=hydraulic&qty=1&item=9-7987
http://www.surpluscenter.com/Instruct/I9-7987.pdf
/ Grapple hook ups #9
Why would this valve not work?
/ Grapple hook ups #10
The valve you linked to 9-7989 is a closed center valve, and will not work with your open center system.
When the hyd pump is pumping with this system, the hyd fluid is flowing through all valves in neutral.
The first valve can take all of the pump fluid and leave none for the other valves.
If you use the above open center valve 9-7987, and feather the FEL, then you can activate the grapple at the same time.
You can't tee into a hyd series flow as the fluid will take the path of least resistance.
/ Grapple hook ups #11
The valve you linked to is a closed center valve, and will not work with your open center system.
If you use the above open center valve and feather the FEL, then you can activate the grapple at the same time.
I wasn't the original poster I was only asking the question. I had also given the OP a new part number for the same unit with an open center I guess I should have stated that before I asked the question oops.
So the same question (not with tee but in series) if he used the valve with the open center he should be ok right? I am asking because I was looking at the same valve and had the same idea, but I am also looking at the diverter valve and using the curl circuit it seems way easer!
/ Grapple hook ups #12
/ Grapple hook ups #13
Yea the 9-7852 valve is the one that I had printed out.
I am just trying to justify if doing all of the extra work and spending the extra money is worth it to go the other route. I really can't see any benniffett to going with anything else for a regular Joe homeowne. If I were doing commercial landscaping maybe maybe not. Just how many times would a person need to curl and clamp the grapple at the same time, heck I am not even sure if I am talentated enough to do both at the same time! :laughing:
/ Grapple hook ups #14
I agree, waaaaaaaay easier. With my grapple, I have not found one single time that I would have been better off being to be able to curl and close the grapple at the same time. It just is not that big of a deal IMO. ;)
/ Grapple hook ups #15
I agree Brian...its just not that big of a deal.
/ Grapple hook ups #16
I assume you where trying to quote me?
It is Closed Center, I know we have already established that and corrected that error-but I was the first to respond. It is also limited to 5 GPM, and according to TractorData the OP's tractor has a flow rate of 9.5 GPM.
And, I believe that style of valve requires power all the time to one of the spools since it's a "spring return to center" type valve. If a fuse blew or a coil failed the flow of oil would be stopped-that could cause overheating and/or other damage if it was not noticed quickly.
My:2cents:
2014 KENWORTH T370 QUINT/A  DUMP TRUCK (A59906)
2014 KENWORTH T370...
2020 FORD F-550 CAB AND CHASSIS (A60736)
2020 FORD F-550...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2020 Deere 544L (A60462)
2020 Deere 544L...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
2023 CATERPILLAR 320 EXCAVATOR (A62129)
2023 CATERPILLAR...
