Coyote machine
Super Member
- Joined
- May 4, 2009
- Messages
- 7,663
- Location
- Southern VT
- Tractor
- 22 SANY SY 50U, '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 BB, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Brush Mower. Diamondplate aluminum canopy
I tried taking the top plug out on the right and it flowed out of the top and still dripped out the bottom. I hear the squeal coming from the tight side front going down the road yesterday for the first time thinking something inside because i still can't drain out and when i stick a nail in the drain feels like somethings blocking it . I'm going to call around other dealer here in maine. Connie is not a nice lady but she dose her job well to well this is the last tractor i will buy from kioti. If i need a new one in the future i will spend more for a Massey ferguson again
So as I suspected your 'squeal noise' is NOT related to the 'kit' that was mentioned in an earlier reply. The kit is for a squeal in reverse that some Kiotis with HST transmissions exhibit when being driven in reverse and infrequently in forward.
Your issue seems to be with your right front wheel/axle assembly. Humor me and try something. Check all your lug nuts on all wheels and see if any are loose. If not fine. If so, then tighten them up and see if that helps with the noise from your right front wheel.
The other possibility is less likely but could be related to the noise. There might be some metal in the right wheel bearing- I'm not saying there is, just saying its possible.
At this point I defer to those here who have more intimate knowledge of the front axle assembly.
Sorry to hear Kioti HQ is giving you a run around. Please don't give up on Kioti yet- they are great machines, and unfortunately poorly represented at times by those who really need to be looking out for us- the retail customer.
The members here will help you find a solution to your issue with your tractor!:thumbsup:
