Massey 135 gears will not engage
   / Massey 135 gears will not engage #11
G,Day johnking.
try this and let me know the results .
Start the engine and engage the pto That is Press the clutch pedal all the way down and move the pto lever TOWARDS THE REAR of the tractor, slowly let the clutch come up and note how far the pedal moved WHEN THE PTO STARTED TO TURN write it down .
The TRANSMISSION CLUTCH When properly adjusted you should be able to put one of your skinny fingers between the pedal and the footpeg where the clutch pedal rests, the gap should be about 1/4 to 3/8 "inch that is there should be NO PRESSURE ON THE PEDAL it should just flop up and down in this area.
Let me know the results and I can tell you what is wrong.
happy Days .
Hutch.
She is at the shop. I will report back the findings.
Clutch lining had gone bad. New clutch and rear end seal and I am now back in action.
   / Massey 135 gears will not engage #14
That's good to hear. Bummer the clutch was bad. The owner probably knew that too. Are you gonna leave that 3 on the front? :)
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A50322)
2017 Kawasaki Mule...
24 Foot Wells Cargo Enclosed Trailer (A50324)
24 Foot Wells...
2001 STERLING WATER TRUCK (A51243)
2001 STERLING...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2021 FREIGHTLINER...
71055 (A49346)
71055 (A49346)
2021 New Holland C327 Compact Track Loader (A52128)
2021 New Holland...
