Fire Department Tractor Rescue Training
/ Fire Department Tractor Rescue Training #1
OTFD122
John Deere 1023E
I am on a Fire Dept and also a member of our training commitee that plans and conducts bi-weekly training drills. We wanted to conduct a different training than we have ever done before... So being the tractor enthusiast I am, I thought, why not tractor related emergencies? So we reviewed tractor safety in the classroom, than took to the farm for a few hands on demonstrations. One scenario was a PTO entrapment, the other was a loader failure, pinning a person. Here's a few pics for you guys!
Our farmer, Stewie:
Loader failure - using Hurst airbags to free victim:
PTO entrapment - Makes for a good demo!
The "non-tractorers" of the FD really enjoyed getting their hands on the equipment and learning how destructive a PTO can be
/ Fire Department Tractor Rescue Training #2
Great idea! Ripped the stuffing right out of that big dummy didn't it!
/ Fire Department Tractor Rescue Training #4
that's an excellent training. I'm a FF also in a rural area and also a tractor dealer. this would be a good training. like the pics. Good job.
/ Fire Department Tractor Rescue Training #5
Same here ff in rural area, we need more if this type of training thanks for posting!
/ Fire Department Tractor Rescue Training #6
I assume speed was not a priority since this was just training. Now my question, how fast were you able to raise the tractor and free the dummy?
/ Fire Department Tractor Rescue Training #7
Great training.
Just training, so you are correct, speed was not a priority. We tried a couple ways, the fastest and most down-and-dirty (and least safe) method was to have everyone lift the front end by hand. The airbag method, much safer and controlled for us and the patient, took around 5 minutes, and that's likely the method we would use if it was an extremity or two trapped and there were no immediate life threats (i.e. someone not breathing)
/ Fire Department Tractor Rescue Training #9
Regarding the loader entrapment, is it assumed that the loader has weight in it at the time? Seems like otherwise, the fastest approach would be to just float the loader and then have people lift it off. If you can lift the front end of the tractor, you can float and lift the loader much easier.
Then again, if somebody is trapped under the bucket, maybe you don't want to screw around with the joystick.
/ Fire Department Tractor Rescue Training #10
My cousin got his fingers ripped off while trying to bump the pto by his sister to hook up the pto shaft. Th pto selector to allow it to spin was broken so they were bumping it to line up the spline and had several fingers ripped out but still dangling via skin. the medics were able to slow down the bleeding and keep fingers alive so it could be sewed back on. I never knew it happened till Xmas time when I saw how swollen they were.(happened in fall).
Funny thing is that the dairy farm went belly up and he became an ambulance medic since.
/ Fire Department Tractor Rescue Training #11
Looks like some great training! Thanks for the pics.
We did some training like that last fall, but instead of lifting parts of a tractor, we lifted a school bus off a car:
Our scenario was that our "farmer" had some fence posts in the loader that he was securing when the loader failed... We just didn't have any real fence posts to put in there!
With the loader joystick, usually we do a lockout/tagout type procedure with any equipment entrapment, that way everything is secured and no one is hitting buttons or moving levers they shouldn't.
/ Fire Department Tractor Rescue Training #14
Ahhh.. I was about to ask the same. So... Lets say the loader has failed (it would be like being in float mode) you would have to raise the tractor a long ways to get the weight of the loader off the victim. Did you guys explore other methods to just relieve the loader pressure and not move the tractor?
/ Fire Department Tractor Rescue Training #16
That was my thought too. If the loader has failed, raising the tractor will not raise the loader until the tractor is way up in the air.
/ Fire Department Tractor Rescue Training #17
Might be messy but unscrewing the hydraulic lines at the lift cylinders would that allow you to lift the bucket other than bucket being honkin heavy by itself?
/ Fire Department Tractor Rescue Training #18
Why not crank the engine, and lift the bucket with the joystick? If it were me under that bucket, I would be begging for it to be off of me in the most expedient method possible.
/ Fire Department Tractor Rescue Training #20
Standby while I call my VFD, I just got burned!
2018 Chevrolet Tahoe SUV (A66738)
2018 Chevrolet...
(INOP) 2006 INTERNATIONAL 7400 DUMP TRUCK (A65054)
(INOP) 2006...
2015 CHEVROLET CAPRICE CAR (A66091)
2015 CHEVROLET...
Vortex Walk-Behind Paint Sprayer (A64553)
Vortex Walk-Behind...
10ft Fork Extensions (A66734)
10ft Fork...
2019 Toyota Camry Sedan (A66738)
2019 Toyota Camry...
