Toplink Speeco Toplink experiences
/ Speeco Toplink experiences #1
Scooby074
Super Member
Nova Scotia
BX 25, ZD 326
Anybody familiar with the Speeco toplinks? My factory Kubota is bent pretty bad .
Are they particularly tough (well tougher than factory)? Well built?
/ Speeco Toplink experiences #2
A top link should not be subject to the kind of uses and treatments that would cause them to fail.
If you bent a Kubota top link, chances are that no top link is going to stand up to whatever caused the original to bend.
Sounds like you might consider buying a disposable top link (as cheap as you can find) and discard it when it bends. Or...figure out what caused the bend and think about ways to avoid the situation.
/ Speeco Toplink experiences #3
Speeco is an old-line company and has made serviceable accessories for a long time. I've never considered Speeco to be top-shelf accessories. The brand typically is quite good and they have an attractive price....they may meet but likely would not exceed the OEM equipment....at least in my experience. Not clear on their top link....and never owned one.
:2cents:
Use of the Box Blade is what caused it to fail. I wouldnt say excessive use or abuse, but genuine use. Probably harder use than alot of people on here do to their "babies" though.
It's still serviceable, however it's got a few degree downward bend on the attachment end.
Plus, I dont like Kubota's adjustment mechanism. I have to carry a prybar to adjust the TL length. I have thought about building my own TL using the ball ends off the Kubota link and a ratchet binder. Ideally I'd go hydraulic TL, Ill have one eventually, but the money isnt there for that right now.
/ Speeco Toplink experiences #5
I dunno what bent it...maybe you should consider a hydraulic top link...so you can lift it and avoid bending??
OK...I see your recent post...yep, I DO recommend a hydraulic top link...you get more function, gonna do some welding, anyway..now's the time.
/ Speeco Toplink experiences #6
I have had a 2 speeco toplinks which were on the 8n. I never had one of them break, the one was just on there for years and wore out. The OEM ones the Bobcat and the Kubotas have turn so much smoother.
/ Speeco Toplink experiences #7
Check surplus Center- they have great deals on stuff (of course you have to be looking for it...)
What about replacing the bent end?
If you can afford to, definitely upgrade to a top and tilt-
/ Speeco Toplink experiences #8
We have both - a Speeco on the B5100, and the original Kub on the L3240.
The Kubota unit seems to be a much heavier, sturdier construction and has a grease fitting.
Went to buy A Speeco today.. none in stock for the correct size.
Did look at the construction however, they seemed to thread pretty smooth. Ill have another gander at them when they are back in stock at Princess.
/ Speeco Toplink experiences #10
Is the OEM toplink hard to adjust because it's bent or because the the toplink is under load when you are doing the adjustment? Years ago I bought several toplinks, including a Speeco, thinking changing the links would be easier than making an adjustment when changing implements. Then I figured out if there's no load on the toplink, it's easy to adjust, and have no need for the extras anymore. I expect you already know all about that, but just saying...
Also, don't forget the "weakest link" principle... if you replace the weakest component (i.e. the toplink), with something stronger, the next weakest component becomes vulnerable, which is probably whatever the toplink is attached to. If it's the rear end that fails, it's going to cost a whole lot more than another toplink. Again, and with all due respect, I'm just saying the 3 point linkages should not be bending under normal operating conditions. Of course, if the original toplink was defective, that's a different story.
Good luck sorting this out, Jason. If you were closer, I'd let you have one of my spare toplinks.
Grandad4
Thanks for the offer!
I admit, I do use my tractor to its limits. Im not really upset that the Kubota unit bent.
Using the BB, you have to make somewhat frequent angle changes, and the Kubota unit is hard to adjust in that there is no handle, so you have to use a screwdriver or whatever is handy in the metal loop.
Its hard to adjust mostly because of the bend in the threaded section. Its hard, but not impossible.
Ideally, hydraulic is the answer and It will happen.. just not sure when because Im looking at over $400, probably $500 to get the top link and valve setup.
/ Speeco Toplink experiences #12
You may wish to consider a Hydralink, which has some shock absorbing ability.
I purchased a Category 1 Hydraulink recently to use in conjunction with my Bush Hog Rollover Box Blade. [Purchased via eBay.]
Have not installed it yet as I have a limb backlog to deal with using my Wallensteim PTO Chipper.
Should have the Box Blade on the 3-Pt with the Hydrulink installed within 10 days to 2 weeks.
I will report on TBN how this combination works for me.
Link + VIDEOS
HydrauLink - a self-contained air over hydraulic top link
2001 John Deere 6210 Tractor w/640 Loader LEFT HAND REVERSER (A64047)
2001 John Deere...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
John Deere 652R 52in Stand-On Commercial Mower (A56857)
John Deere 652R...
2017 FORD F-150 FOOD TRANSPORT TRUCK (A63569)
2017 FORD F-150...
18' Utility Trailer (A64047)
18' Utility...
2011 Jeep Grand Cherokee Laredo SUV (A61574)
2011 Jeep Grand...
