claypidgeon
Thinking about goe mageeing something up to the oil sensor hole and running preshureized oil to check flow. What do you think, just might work or not?
ctiguy
I'm not familure with your crow realise hatch or pondering wrench hole. What are you talking about? Draw me a diagram, I need visual conformation.
Let me explane..
AS to my term "Joe Megge", I was refering to rigging something up to work in away you might not see done in a shop.
Let me explane..
My problem is a rod bearing fried. I suspect it is due to a lack of oil to one lobe of the crank. That oil is suplied through the crank and surfaces through a hole in the jurnal. My pan is off and so is the head. I know that oil was getting to the other jurnal and also to the rocker arm asembly. I am suspicious of the problem area because of the fried bearing and the fact that I ran a wire up the suply hole and it came out dry. AS to my term "Joe Megge", I was refering to rigging something up to work in away you might not see done in a shop. The oil pressure sensor is mounted on the side of the block, the hole is threaded, and it is near the leavle of the crank. It seems reasonable to me, that if I remove the sensor and screw in a fitting that I can hook up some tubing to and run oil through the lower end of the oil track, I could find out if the passege way was clear to the crank jurnal in question. My question to you guys was " good idea, bad idea?". I do not think there would be any problems created by doing this, just thought I would check. Sorry about my spelling, I meant Bad not dad and joe not goe.
Ran the oil flow test and all is good. Nice solid flow. Should get the head gasket tommorrow. I'll retorque the rod caps and put the pan back on while I'm waiting. There was no thermostat in the head when I took the thing apart. Contiplating putting one in. I't not that cold here in the winter but I live at nearly 3000 ft. We get alot of days in the 30's and 40's, I probably should. Any input on that?
Ken..
The tractor is an early 80's Satoh Bull. the engine is a Mitsubishi KE130. Two cylinder deisel. AS to how the engine ran, I cann't tell you because it has never ran long enough for me to find out. I have been learning along the way about all the problems this rig has. The bearings were worn paper thin and the crank jurnal was scared. There was no way to plastic gauge them. Because of this I had to order bearings a size over and polish the crank the best I could and install them to check for play. I know this will not last forever but I might get some time to find anouther motor or save up the money to rebuild this motor from the cank up. I guess maybe it might be benaficial to not install a thermostat to keep the engine as cool as posible to maybe get my patch job to last a little longer. As to weather I have rebuilt an engine befor, not a deisel. However I have worked on lots of other engins from small utility motors up to V8's. All at home and flying by the seat of my britches. Most of the time I can figure things out but always apriciate any input I run across. I'm never afraid to ask questions and read manuals most of the time.
Ken
you are probably right about the motor needing all bearing replaced. I will most likely get to that next year when I split the tractor to replace the clutch. The clutch still works but is adjusted all the way out. Iv'e never heard of a self cleaning bearing shaft tool. I suspect there is away of hand turning just about anything. There are places in the world were the nearest machine shop is over a thousand miles away.
