JD 1020 - what is the correct tire pressure?
   / JD 1020 - what is the correct tire pressure? #1
Figato
Member
1967 I believe.
Typical Ag tire setup.
Yes, I looked at the sidewall - no pressure listing or it wore off :)
Thanks!
   / JD 1020 - what is the correct tire pressure? #2
Most Ag tires run between 8 to 20 psi. The never exceed pressure is usually about 25psi. Do you know what brand of tire they are.
Did you look on the backside of the tires.
   / JD 1020 - what is the correct tire pressure? #3
Tire pressure isnt a carved in stone pressure. It all depends on the tool being used in relation to tractive issues. Do a google for tractor tire slippage for in depth reading on the matter.
Thanks.
I did look at the back, but might have missed it.
Tractor is at my hunting land, so I'll have to come back with tire brand.
   / JD 1020 - what is the correct tire pressure? #5
What sizes are front and rear?
Are rear 4 or 6 ply?
   / JD 1020 - what is the correct tire pressure? #6
I second this for the rear tire. The rears should be best traction at 8-10 PSI. I dont think a 1020 would have the capcity to carry anything large enough to require more than about 12 PSI. Depending on the size front tires they could be anywhere from 30-40 PSI. There should be a maximum inflation pressure on them somewhere. It will be pretty small writing but should still be legible. I have never seen one that was worn off as there just isnt any wear on the side walls.
2006 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2006 Toyota Tundra...
2020 Case TR310B Skidloader (RIDE AND DRIVE) (A50774)
2020 Case TR310B...
2016 FREIGHTLINER M2 REFRIGERATED BOX TRUCK (A51222)
2016 FREIGHTLINER...
2019 Isuzu NPR-HD 24ft. Box Truck (A50323)
2019 Isuzu NPR-HD...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
2019 Doosan DX225LC-5 Excavator (RIDE AND DRIVE) (VERY NICE) (A50774)
2019 Doosan...
