Compression release on tractor
/ Compression release on tractor #1
stampede38899
North Carolina
Tiashan Dragon 270
i recently bought a taishan dragon 270 and was wandering what the compression release was used for and how is it suposed to be used. never saw this on one.
/ Compression release on tractor #2
On a motorcycle you pull the compression release lever and get the engine to tdc then release the lever and kick. Be careful when kick starting your tractor. It has a lot of compression.
On my chainsaw you press the compression release and it locks in the active position. Then you pull the starter cord and it automatically releases.
/ Compression release on tractor #3
Had one on my old L185 DT. I used it in the extreme cold when I couldn't get the engine to turn over under compression. I would release the compression after glow, crank the engine and reengage the compression once the engine is spinning. It was never as effective as warming the engine with a shop heater when it was really cold out. Don't know if that was the proper procedure but it worked for me.
/ Compression release on tractor #4
Compression releaseon a diesel engine is a starting aid. Activating it by pulling a cable or turning a lever causes one set of valves to open slightly, temporarily disallowing compression. The starter motor then has a much easier time turning the flywheel, saving wear and tear on itself and on the battery. It also turns the oil pump, which then starts pushing oil back into the now-empty passages. My procedure was to open the compression release, engage the starter, then watch the oil pressure gauge. As soon as it was spinning fast enough to indicate pressure on the gauge, I'd let go of the compression release. Except in the coldest of conditions, that was usually enough to start on the first try.
//greg//
/ Compression release on tractor #5
+1, particularly the part about building oil pressure without applying load to piston and rods. This saves a lot of wear on crank and rod bearings by allowing an oil film to be built before compression load is applied. Also, diesel starters are very powerfull. If for some reason some moisture has found it's way into the cylinders(leaking head gasket or rain down the intake or exhaust ect), compression release allows this fluid to be expelled. If it is not, this could cause a hydraulic lock and the starter can be powerfull enough to bend rods, twist the crank or damage flywheel and starter...
I use mine on every start...
/ Compression release on tractor #6
While on issue. Hickory Creek here. In old posts, I have stated that my SL 3105 engine will run with compresssion lever engaged. First, thanks to all, I have used the heck out of the tractor this year. Now, I have not tried to adjust compression release. I assume one removes valve cover. From there, are there any alingment marks or does one adjust nuts on linkage whatever so valves open just slightly or what? I am having to use two batteries to start this thing unless I use starting fluid.
/ Compression release on tractor #7
The odds are that the compression release lever is not properly engaged inside the valve cover. On my 304 Jinma there isn't anything to adjust - it either is correctly position to lift the exhaust valves or it isn't and then it doesn't work. If you pull the valve cover you should be able to see =what needs to happen - it is a simple lever arrangement on mine.
/ Compression release on tractor #8
On my 354 Jinma it is very easy for the lever to come disengaged when I take the valve cover off. With the valve cover off, it's pretty easy to see how it works -- there is a shaft that runs parallel to the valve train that pushes down on the valves when it is turned. There is a lever on the outside of the valve cover that turns that shaft when it is pulled. Connecting the lever to the shaft is a metal dowel, about 3/8" in diameter and 5/8" in length, with a slot on each end. That dowel tends to fall out when the valve cover is removed, and then roll to the most inaccessible spot in the shop. It takes a lot of fiddling to get the valve cover, lever, shaft and dowel all aligned properly on reassembly. What I have to do is unbolt the lever, assemble everything else and then bolt the lever back on.
With the valve cover in place you can easily tell by pushing on the lever whether it is engaged properly -- there is either a lot of resistance, or none.
/ Compression release on tractor #9
First thing to do is to make sure the linkage from the operator station to the valve cover is actually connected - on both ends. Then confirm that - when engaged from the operator station - there's actually rotation visible at the point where it goes through the valve cover. If those two things are happening - and you still have no compression release - only then should it be necessary to remove the valve cover. Let me know what you find before actually taking the cover off, and we'll go from there.
//greg//
So this is an aid to help with cranking, do they use that instead of glow plugs in these chunese tractors? i beleive my tractor has the plugs as my switch has a place for it.
/ Compression release on tractor #12
Mine has no Glow Plugs. Without the compression release, it takes over 1000 amp of battery to spin engine fast enough to start w/o starting fluid. Engine turns over slow with 750amp battery. Originally, tractor had 2 - 6 volt batteries in series to give amperage.
Yes, lever from operator seat works fine. I use to stick my hand at back off engine and pull linkage while using a screwdriver to jump solonoid before I fixed starting circuit. I am in no hurry and will get to it in a month or so after I get some more chores done. Sure would like to move to the islands Rich. Is it paradise there?
/ Compression release on tractor #13
Well, I've never needed starting fluid. (grin) Of course, I wouldn't use that stuff in a diesel no matter what. Way to easy to trash an engine that way.
/ Compression release on tractor #15
You may have more than one problem. The SL3105 is a direct injection engine, and should start much easier than that - with or without compression release. I'd be curious to learn whether the compression release stopped working after someone performed a valve lash adjustment. Did you buy this tractor new? or used?
//greg//
/ Compression release on tractor #16
Ok, for those of you who don't remember me, here is the start.
http://www.tractorbynet.com/forums/chinese-tractors/235000-help-worktrak-404-29-4kw.html
If I do not use starting fluid, I need my car battery connected to tractor with car engine running to crank this thing off. Really need to spin up starter. And at that, it takes 6-8 seconds of constant cranking to fire it off. It seems like when I pull the fuel shut down lever, it removes all the fuel from pump and system and it takes 6 seconds of cranking for it to build back up before it will even attempt to try to run.
How long should it take to crank one of these?
/ Compression release on tractor #17
About 2 - 4 complete revolutions max for the DI engines. It's very unlikely that the fuel is siphoning back to the tank because the fuel level is always above the injection pump (flooded suction).
Curious if you are getting white or black smoke whisps from the exhaust during startup (sans starting fluid)?
Your injector timing could be a little retarded. Engine could also be low on compression.
/ Compression release on tractor #18
Depends on the temperature, but this time of year it should be running within 2 seconds. Again, new or used? And to your knowledge, has the valve cover ever been off for any reason?
//greg//
/ Compression release on tractor #19
Mine has both Compression Release and Glow Plugs. It cranks right over after 20 seconds of glow plugs when its below 40. Above that I use nothing, just start it as if it were my car, truck, boat, ect.
Chris
2007 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2007 INTERNATIONAL...
2000 FREIGHTLINER CENTURY CLASS 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2000 FREIGHTLINER...
2015 Kenworth T800 T/A Wet Kit Sleeper Cab Truck Tractor (A64194)
2015 Kenworth T800...
UNUSED PARBREAK SST23 BEAR SHAPED SHOOTING TARGET (A65055)
UNUSED PARBREAK...
UNUSED FUTURE CAT 303-46" EXCAVATOR RAKE (A65055)
UNUSED FUTURE CAT...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A64280)
(INOP)1989 NISSAN...
