Hydraulic cylinder question
/ Hydraulic cylinder question #1
ferguson123
massey ferguson
Hey all, am looking to build a hydraulic cattle scraper similar to the ones in the images below, it uses a hydraulic cylinder to push the central steel beam up and down the floor, which in turn ratchets the scraper up the floor. The only thing am not sure about is how do i get the hydraulic cylinder to to go in and out automatically without me having to do this manually with a spool valve attached in the pipe line?
/ Hydraulic cylinder question #2
How about a solenoid valve with a timer/relay.
/ Hydraulic cylinder question #3
Are there any pressure switches on this unit?
Limit switches on the cylinder mechanism?
From my feeble memory our manure pump had limit switches to indicate end of stroke so it would auto-cycle.
/ Hydraulic cylinder question #4
That would be one long cylinder!! Are you sure it is not a motor and a chain? I would use prox switches and a timer to do that, hooked to a hydraulic motor with a drive chain and idler. CJ
/ Hydraulic cylinder question #5
Hello CJ,
no, it isn't a long cylinder, take a look at this video:
Wilco.
Ah a ratchet mechanism. I wonder if a chain and a small motor could eliminate some $$$. CJ
i thought a hydraulic cylinder would make it cheaper as i would only need one, if i was using motors i would need two! One at each end, to pull it both ways
/ Hydraulic cylinder question #8
Actually no, 1 motor hooked to a chain and a idler at the other end. 2 prox switches that reverse a small DO3 valve. CJ
2012 HEIL (A60736)
2012 HEIL (A60736)
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Bucket Truck (A60352)
2018 Freightliner...
John Deere 12in Channel Tooth Bucket Excavator Attachment (A60352)
John Deere 12in...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
