teeing into a banjo fitting to add a return
   / teeing into a banjo fitting to add a return #1
quicksandfarmer
Elite Member
Coastal Rhode Island
Jinma 354, purchased 2007
Hi. My tractor is a Jinma 354. I want to add remotes, but I'm having a devil of a time figuring out how to add a hydraulic return.
There is one existing hydraulic return line, from the power steering. It's a hard pipe with a banjo fitting. My initial thought is I could just replace the bolt with a double length banjo bolt and put a second banjo fitting there, but there's a problem: there is about 1/4" of clearance between the banjo and the control lever for the 3-point hitch, so no room to add anything there.
Would it work to bend the return pipe from the power steering a couple of inches and put a new fitting into the hole that is there? I'm thinking a short length of hose with a banjo on one end that would attach to the existing hole. On the other end of the hose would be a female o-ring face seal, which would be held to the banjo on the steering return pipe with a banjo bolt. If I use a double length banjo bolt I could put a second banjo fitting there, on a hose, that would be my return for the remotes.
Is this viable? I'm just guessing that a female ORFS would work. Do they make a hose fitting for a female banjo connection? Any other thoughts?
Thanks.
   / teeing into a banjo fitting to add a return #2
One thing I'd be worried about is backpressure. Banjo fittings are restrictive already. There is a slight chance that you will have steering issues when you try to dump all the aux flow through the fitting and pressurize the tank side of the PS pump/valve.
Is there a fill cap you could modify to accept a fitting?
ISZ
ISZ
The fill cap is under the seat, you have to slide the seat forward to check/add fluid. I don't think there is clearance to do anything.
Anticipating your next question, there is no drain. The power steering return goes into the hole where the parts manual shows the drain plug.
   / teeing into a banjo fitting to add a return #4
is the sump cast iron?
got a drill bit?
got a pipe plug tap?
if = yes = no problem :)
I should have said female O-ring boss instead of face seal. IE, a female straight thread.
2015 Top Hat T/A 20 ft. Gooseneck Trailer (A50860)
2015 Top Hat T/A...
2022 Continental 16' Enclosed Trailer with ramps (A49461)
2022 Continental...
2018 John Deere R4038 Self Propelled Sprayer (A50657)
2018 John Deere...
2012 Lincoln MKX SUV (A50860)
2012 Lincoln MKX...
2008 Ford Escape XLT SUV (A48082)
2008 Ford Escape...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
