Is this a good price for a B2620
   / Is this a good price for a B2620 #1
Phila
Troy NY
Kubota B2620
I have just bought my first real tractor a B2620, I have been looking at tractors for years. Mainly looked at the BX series but when it finally came down to it I went for the B series, I just thought this tractor will be better for me in the long run. At this point I have the bare tractor with a 54" mid-mount mower, I would have liked the 60" but due to space constraints in my garage I had to go with the 54". My first question is if I got a decent deal on the machine, I paid $13,699 for the tractor, $1,925 for the deck and a $500 rebate from Kubota so bottom line price $15,124. I also got the 0% for five years. My second question is I want to get a LP brush cutter next spring, I want to know what size I should get, the dealer recommends a 48" but I have seen several posts here saying that people have a 60" cutter with this size machine. Any advice opinions would be greatly appreciated. I will be cutting a 9acre field.
Thanks in advance.
   / Is this a good price for a B2620 #2
Yeah, go 60" on the brush cutter.
The best price I saw for the B2620 was $14700 for the tractor and front loader, with R4 tires.
   / Is this a good price for a B2620 #3
Once you've bought it you got a decent price.:cool2: Never ask after the deed if you got a good price because some insensitive person will always tell you that you could have gotten it for less and then how will you feel? Just don't do it.:)
I believe a B2620 will have the HP to pull a 60" if that's what you want. The heavier the brush cutter the more apt it is to swing the tractor around and if your on level land that shouldn't be a problem. Also what your cutting ( good sized trees, etc) makes a difference. Just high grass with less than one year old saplings aren't that bad.
   / Is this a good price for a B2620 #4
Depends what you need to do with it. A lighter duty 60 for pasture clipping will be fine. A heavy duty (3" capacity) for rough work, not a good match for this machine.
The land I would be mowing is basically long grass and golden rod maybe a few 1/2" sapplings.
1995 FORD LT9000 DUMP TRUCK (A45678)
1995 FORD LT9000...
2005 Ford F-250 4x4 Crew Cab Pickup (A46684)
2005 Ford F-250...
Hot Stick 12ft Trailer (A48837)
Hot Stick 12ft...
2006 Kubota M5040D 4WD Front Loader Utility Tractor (A46683)
2006 Kubota M5040D...
2003 Jeep Liberty 4x4 SUV (A46684)
2003 Jeep Liberty...
Stainless Steel Sprayer (A49251)
Stainless Steel...
