Stalled the engine on my 2520 using a chipper
/ Stalled the engine on my 2520 using a chipper #1
RanchHand2520
JD2520
I was using my 2520 and Wallenstein BX42 chipper the other day and fed it a branch bigger than it could chew and it stalled the engine. I started it right back up and about 30 minutes later (after I unstuck the branch that the chipper blade only went half way through) proceeded to chip for another several hours. I have not noticed anything but after seeing the post on the problems with the 2305 pto/transmission, was wondering if I should be concerned? Any input would be greatly appreciated. Thanks!
/ Stalled the engine on my 2520 using a chipper #2
I'm 99% sure the new 2 series units have a redesigned PTO housing. I was looking at buying a used 2305 when the 1026R came out as the JD delers were getting 2305's in on trade. Then I read all the horror stories of the PTO housing failures and now I wouldn't consider buying a 2305 or a 2210. You should be good to go on your 2520. Most of the stories I read, the problem was obvious and terminal where the PTO was no longer functional.
/ Stalled the engine on my 2520 using a chipper #3
Hiya,
The 2520 is completely different than the 2305/2210 series. I ran a 5 foot tiller, a 5 foot snow blower and a RFM for several years on the back of a 2520 with no issues. Just remember, on/off at low RPM, be kind to the clutch pack.
I can't remember reading of any failures of the 2x20 series PTO on this or other boards, the gear reduction housings and axle seals are another story, there have been a few posts regarding them.
Tom
/ Stalled the engine on my 2520 using a chipper #4
I have the same setup and the same happens to me from time to time. (Touch wood) i haven't had any real negative repercussions resulting from this, other than my pto brake/clutch which has stopped working but i don't know if i can attribute that failure directly to these chipper mishaps. I find the machine handles the green 4" much better than the dry, petrified dead wood, which seems to bog it down. Problem is once it start feeding these big logs, its pretty difficult to stop it. You gotta be on the ball and yank it out before it causes a stall. As mentioned in the earlier post, I turn down the rpm before i restart but make sure i get rid of the obstruction before i re engage the pto.
Have fun chipping !
... I find the machine handles the green 4" much better than the dry, petrified dead wood, which seems to bog it down. Problem is once it start feeding these big logs, its pretty difficult to stop it. You gotta be on the ball and yank it out before it causes a stall...
Thanks everyone for the feedback! I'll second that regarding chipping green vs not so green and trying to stop it once it gets a bite of a branch. I had no problems this spring on fresh cut branches but didn't quite finish the stack. I stalled it out on the same size of branch - it had just dried out over the summer.
/ Stalled the engine on my 2520 using a chipper #6
I apologize for not understanding this fully and would seek some feedback regarding pto brake/clutch. My situation is a bit different but the result of stalling the tractor is the same. I have been putting in fence posts and because of the location...I can run into a lot of rock. Sometimes the rock is so large, the post hole diggers "rides" on top of the rock because it cannot get past it, other times it "grabs" too big of a rock and breaks a shear pin, or as I experience a couple of times yesterday, the auger just bogs down and stalls the tractor. In all the aforementioned examples, the engine is runing at the slowest speed. Am I damaging my tractor when the load on the PTO cause the tractor to shut down?
/ Stalled the engine on my 2520 using a chipper #7
Not an unusual issue, it's a matter of buying the right tool for the job. In your case, Wallenstein recommends a minimum 35hp for the 42 series chipper. I don't know if that's engine or PTO horsepower, but I'm sure your 2520 falls well short on both. I'm thinkin' you'd fared better with the 32BX series., and even then they recommend at least 25hp
So to answer your question, yes. I think you should be concerned. You're trying to run more machine than the 2520 is spec'd to handle.
//greg//
... Wallenstein recommends a minimum 35hp for the 42 series chipper...you'd fared better with the 32BX series., and even then they recommend at least 25hp...
I definitely agree with you - if I had a tractor with higher pto hp on the range Wallenstein recommends, I probably would not have stalled it but I did so I asked the question.
FWIW, Wallenstein's recommended hp range (pto is my guess) for the BX42 is 18 to 50 and for the BX32 is 12 to 30.
BXs Series Wood Chippers - Wallenstein
JD specs the 2520 at 20.5 pto and 26.4 engine, so either way I am in the range.
/ Stalled the engine on my 2520 using a chipper #9
I'll guarantee most folks have jammed their chipper up sometime or another. If it's direct drive, you'll stall the tractor...if the chipper is belt driven, you'll smoke the belts.
Mine, a Woods 5000, is belt driven and I've had a couple jams when chipping old dried out branches.
/ Stalled the engine on my 2520 using a chipper #10
Yep it happens... I stalled my 52hp (40 something PTO) with my BX42 once - just grabs something the wrong way and that is all she wrote.. Getting it unjammed that time sure was fun!!!
/ Stalled the engine on my 2520 using a chipper #11
Not for whatever you stalled the engine with. Take another look at that link you posted, and note the "hp requirements for max cap". With chippers, you worry about the top end. Bottom and middle don't mean squat. I still maintain the BX32 is a more appropriate match for your 2520.
//greg//
/ Stalled the engine on my 2520 using a chipper #12
One more reason to avoid pro driven post hole augers . Instead use the loader bucket mounted hydraulic driven post hole auger.
If stuck, it just stalls. Reverse the auger and good to go. Down pressure too for digging dry clay soils.
/ Stalled the engine on my 2520 using a chipper #13
The main difference between the BX-32 and 42 -- in terms of what the tractor can support -- is the size and shape of branches you can/should feed in. I can see how it's possible to overload a tractor more easily with a 42, but that's about it.
Used sensibly, the 42 should be fine on a 2520. I run one on my Kubota B2920 (21 HP PTO) and it works like a charm. I generally only chip stuff smaller than 3" diameter; anything bigger goes to the firewood pile. When chipping dry branches, I try to send a green branch through every once and a while. I chip beech, oak, maple, and pine.
Just because the chipper is rated to 4" diameter doesn't mean you need to feed it that way; in fact, the main benefit of the 42 to me is that the feed chute and 4"x10" opening can more easily accommodate branches that might be crooked, twisted, or in bunches. That doesn't stress the capacity of the tractor or chipper, but it does significantly improve productivity and workflow. Given the prices, I'd only suggest a 32 if the 42 was physically too big. The 42 is a better value, easier to use, more productive, and will have much better resale appeal. Just don't hook it to a tractor on the low end of the HP range and then send an oak 4x10 through the chute!!
/ Stalled the engine on my 2520 using a chipper #14
I agree with s219. I have a 2520 and a BX42 and have never had a problem with it. Granted 4" stuff usually gets bucked and burnt, but not always. I have lots of chipping hours and no issues.
