What a brute!!!
/ What a brute!!! #1
Mechanos
Roosterville, MO
JD 955/70A/7 TLB
Did my first heavy work with the 955 tonight. I finished up the rebuild late Friday night a week ago, and then woke up sick as a dog the next morning. That put me out of commission all of last week. Over the weekend, all I got done was mowing... the place got away from me and was way overdue. Some areas I had to use the brush hog to knock it down and then come back and finish mow it the next day.
Anyway, I've got an area next to my barn that I've been wanting to excavate for a trailer parking pad. The calculated volume of dirt that needs to be removed is about 78 ydウ. Got about 30 to 35 of that dug out and moved to a stockpile in a about 2 hours. I absolutely love the 4wd with R1's for dirt work! A brand new set of loaded Goodyear DynaTorque II's are just plain mean when it comes to traction. The extra ponies under the hood didn't hurt either.
I was also quite impressed with the 70A loader... quite powerful for this size of machine. The 60" bucket with a 7-tooth toothbar easily took heaping bucketfulls out of the undisturbed clay. It's so much fun, it's almost like I'm not working!
Not sure I really like the new subbed exhaust pipe's exit location, though. Seems like I'm eating more exhaust fumes than I did with the original "exit through the side panel" exhaust pipe.
In summary, this thing is a beast.
/ What a brute!!! #2
All that and no pictures???? Shame on you! Really though, sounds like you got it running very nicely, glad you are having a blast on the beast!
/ What a brute!!! #3
Glad it worked out for you and you are getting such good results. Don't forget we want pictures or it didn't happen.
Don't forget to pet your dog either.
/ What a brute!!!
Too busy working to take pictures, I can't take a picture of myself working, it was dark when I quit for the night. So, close your eyes and imagine a big pile of dirt...:laughing:
/ What a brute!!!
OK. For all you picture mongers out there....
Here's the rough cut:
And here's the stockpile:
/ What a brute!!!
More pictures for the non-believers
Scooping up a bucket-full:
Backing out of the cut:
Headed to the stockpile:
Headed back in for another bucket bite:
/ What a brute!!! #7
Thanks for the pics.
What hydraulic pressure does a 955 run? And if you dont mind, what gauge material are the arms of the loader made from?
Thanks agian.
/ What a brute!!! #8
The only line (s) I can see are the screw heads holding the metal siding on in the first photo and I am looking at the photo's on a very large high resolution monitor.
/ What a brute!!!
...One question. How did you manage to get it level when the tractor was starting out on a grade? Not being experienced that is always a hard task for me...
Simple. You take your first few scoops and dump that dirt on the low side of the grade. Back drag it or whatever to level it out, run over it a few times to pack it down. Basically build yourself a level pad to get the tractor sitting level and the bucket on the plane you desire. Then begin digging with the bucket. Once you get far enough into the cut, you can back in and cut out the pad you just built to the elevation you want. As far as staying on that elevation, it's just bucket control that you'll get the hang of. I usually do end up with a few high and low spots and use the box blade to do the final leveling and grading.
/ What a brute!!!
Do you have a tooth bar on the bucket? Looks like it is doing a great job.
Yes. 7-tooth tooth bar on a 60" bucket. It would never cut into that hard clay like it does without teeth.
/ What a brute!!! #12
Really wish the 855 had the same lifting power that the 955 has.
/ What a brute!!! #14
What are you using for rear ballast? Even with the toothbar, I'm a bit surprised you didn't lose traction.
/ What a brute!!! #15
Nice looking photos ,,looks like it is doing a great job, tooth bar doing a good job.
This spring I dug out a handicap ramp into basment of our church . Sure wish I had a toothbar ,first I would scope then turn around use BH, then scope ,then BH ... . Did this for complete ramp 4'deep x11' w and 36' long. took out 6 --6ton dump trailers of dirt ,,and at least 10 ton of rocks.. one was at least 53" wide. and 8-10 high and guessing 20 depth just barely stayed in my 54" bucket at least the old 2305 handled job and kept on working
Keep up the good job..
/ What a brute!!! #16
Good job and wow, pictures just make a thread pop as though we were right there. Nice and close work up to the building as well.
/ What a brute!!!
Probably a good thing it doesn't. The 855's front axle and front final drives are a lot smaller and weaker than the 955's.
The rear's are brand new Goodyear DynaTorque II's filled with RimGuard. I also have my Frontier 2060BB hanging off the 3pt with another 160lbs. of old railroad iron bolted onto it above the cutting edge. I can put the hydraulics into relief with the loader and never come close to lifting a rear tire. I do get some wheel spin when digging in for a big bite, but those Goodyears are chewing and spitting out bars of clay. The clay has just about the perfect moisture content for maximum traction... kind of like what you'd see at a truck or tractor pull.
/ What a brute!!! #18
I must say I find the trolling in this thread hilarious and I genuinely enjoyed the pictures. I also am glad to know I'm doing it right when I level myself before digging. I like to use the backhoe to start levelling sometimes because i can level myself with the outriggers and smooth it with the loader. Nice job on the excavation!
/ What a brute!!! #19
I like that idea to level a starting point with the BH so both front and rear axles are level so the FEL bucket cut will come out flat.
/ What a brute!!! #20
I usually cut the high side and fill the low side when I do that. I got the idea from running an excavator where you do every operation with the hoe.
2009 FORD E350 CARGO VAN (A66091)
2009 FORD E350...
2009 ALLMAND  MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
2008 Audi A4 AWD Sedan (A66738)
2008 Audi A4 AWD...
Giyi SZYMJ QA Mini Stump Grinder (A64912)
Giyi SZYMJ QA Mini...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
Pallet of Club Car Golf Cart Seats (A64912)
Pallet of Club Car...
