Fire extinguisher maintenace
/ Fire extinguisher maintenace #21
Good thread! I guess I will pitch my 18 year old First Alert extinguishers and give the local fire extinguisher company a call.
Instead of tossing them, take them with you to the fire extinguisher company. Actually, a few of the older F.A. brand extinguishers were made by Ansul and are a quality product. It should cost less to hydro and recharge them than replace. The Ansuls that I'm talking about will be 5 or 10 pound capactiy with steel cylinders and bright aluminum, square-shaped valves.
Here's a pic of a 10# Ansul Sentry. The First Alert will look just like it except for the name on the label:
http://farm2.staticflickr.com/1007/1449584973_66341591bc.jpg
1449584973_66341591bc.jpg The 5# will look the same, but have bright aluminum handles, and be a bit smaller.
However, if the extinguisher has a plastic valve and aluminum cylinder, it's trash.
A word of caution:
Before disposing of any fire extinguisher, be sure to operate the valve and discharge the contents. Make sure that all the pressure is relieved. If possible, once it's completely empty, unscrew the valve assembly and remove it. The garbage truck driver will appreciate that. ;)
/ Fire extinguisher maintenace #22
It's obvious, Bigfoot, you've forgotten more about fire extinguishers than I'll ever know! However, good info....I have several extinguishers, will use your info to check them for quality.
/ Fire extinguisher maintenace #23
View attachment 282548 The 5# will look the same, but have bright aluminum handles, and be a bit smaller.
A word of caution:
Thats one way. I wonder what a .45 slug would do to one. I shot my old computer a few years ago, that was a good day.
My First Alert has a plastic valve
(3) STIHL POLE SAWS (A64276)
(3) STIHL POLE...
New/Unused Quick Attach Hydraulic Rock Hammer (A65583)
New/Unused Quick...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2008 Bobcat T300 (A64126)
2008 Bobcat T300...
2022 MORBARK EAGER BEEVER 1215 WOOD CHIPPER (A63276)
2022 MORBARK EAGER...
Enclosed Trailer with Lube System (A62613)
Enclosed Trailer...
