1983 Ford 1900 Tractor - Hydraulic Equipment hardly works
   / 1983 Ford 1900 Tractor - Hydraulic Equipment hardly works #1
natan
Shady, NY
1983 Ford 1900
Hi,
My 1983 Ford 1900 tractor has about 745 hours and the hydraulic filter has never been serviced. Last Fall the loader and backhoe took a long time (1/2 hour warm up) before they would even work and then they would rise with jerky motion lifting very slowly. I thought it was the cold weather but this hot July and August it was the same. By the way, at one point without realizing it, I had pulled back on the lift lever so that there was hydraulic resistance. When I pushed the lift lever forward that problem went away. Also I opened the flow control valve and it got a little better but a couple of days ago after I struggled to load some dirt and to grade it and the loader and backhoe nearly stopped working. Today I started the tractor and I was able to lift the loader and backhoe with great difficulty, a foot or so off the ground. I blocked them so they would not drop, figuring I may have to have the tractor transported.
Do you think that it may be the filter? How difficult is it to replace it or clean it and can someone describe the procedure. However, as I increase the RPM I hear some squeaking. Could it be the pump? The fluid is clear. How do I verify if it's the pump and if it is the pump then how to go about replacing it and where I should look to get one? Does anyone have a diagram or details on how to replace the pump.
I really would appreciate some help.
Thanks,
Natan
   / 1983 Ford 1900 Tractor - Hydraulic Equipment hardly works #2
Drain the fluid, remove the suction tube and than the three or four bolts that hold the suction screen flange to the rear axle center section housing. Withdraw the screen, clean it or replace it.
Don't even think about replacing or even touching the pump without servicing the suction screen.
   / 1983 Ford 1900 Tractor - Hydraulic Equipment hardly works #3
Absolutely correct. I'll bet that sump screen is all plugged up. Order the round gasket before you take things apart.
   / 1983 Ford 1900 Tractor - Hydraulic Equipment hardly works #4
When you drain the fluid there are 3 drain plugs. The hard to find one is hid by the draw bar if you have one. Make sure you put the correct oil back in it.
Bill
   / 1983 Ford 1900 Tractor - Hydraulic Equipment hardly works #5
all good advice.......:thumbsup:
Hi Guys,
Your replies game the incentive to undertake this. The screen was really clogged up. I cleaned it with diesel fluid and a tooth brush and then the air hose from the inside and outside. The reward is that the hydraulics work beutifully.
Thanks to each of you for responding.
Natan
   / 1983 Ford 1900 Tractor - Hydraulic Equipment hardly works #7
Hi Guys,
Natan
Glad you are up & running at minimal cost.
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
New Swict 60" Skidloader Bucket (A50774)
New Swict 60"...
Unused 2025 CFG Industrial QNT50R Mini Excavator (A50322)
Unused 2025 CFG...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
John Deere Imatch Quick Hitch (A50514)
John Deere Imatch...
2007 WABASH 53FT DRY VAN TRAILER (A51222)
2007 WABASH 53FT...
