Log Lift Table
/ Log Lift Table #1
tetomas
Washington Ga
64 Ford 4000D
I have a Spee Co splitter that I bought from my local farm cooperative, and I am intent on adding a log lift to it. The splitter has a 10hp engine, 16 gpm 2 stage pump, and a 4x24 cylinder. I have acquired a 2x8 cylinder and a new valve to use for the lift. Looking for suggestions as to what to build the lift table out of, how to figure the mounting location for the cylinder. Any help/suggestions would be appreciated.
Jimmy
/ Log Lift Table #2
There are a lot of threads on the subject. Just make sure your new valve has a Power Beyond port. The splitter valve probably does not. The valves are plumbed in series with the lifter valve first. ITs PB port feeds the power port on the splitter valve. Both valves have return to tank ports which can be teed together. Make sure both valves are open center. They probably are but they have to be the same and match the pump.
/ Log Lift Table #3
I have a Spee Co splitter that I bought from my local farm cooperative, and I am intent on adding a log lift to it. The splitter has a 10hp engine, 16 gpm 2 stage pump, and a 4x24 cylinder. I have acquired a 2x8 cylinder and a new valve to use for the lift. Looking for suggestions as to what to build the lift table out of, how to figure the mounting location for thiohe cylinder. Any help/suggestions would be appreciated.
Jimmy
I built my log lift on my Brave splitter out of 1 1/4" x 1/4" wall square tube. I mocked up the hinge points using some pieces of plywood and c-clamps. I know that youre supposed to use a valve with power beyond but i just plumbed my lift valve inline with my splitter valve and havent had any problems after almost 200 hrs.
/ Log Lift Table
did you plumb the valves in series or in paralell?
/ Log Lift Table #5
You have them in series, again with the splitting valve last. This is also how I have my splitter set up only I have 4 valves inline. The first is an aux hook up for a hydraulic dump trailer, the second is for the hydraulic jack, the third is for the log lift, & the 4th is the splitting cylinder.
As far as designs for a log lift, browse thru the past threads & you will find several different approaches. Some make them in an "L" which allow you to stand on them. Others (myself included) have a more open angle (30 - 45 degree). The advantage to this is you need less of a stroke to move a lift 45 degrees than the "L" which has to move 90 degrees to be level to the splitter. It also has a larger work area & will allow you to pile more wood on it if you place it in a half raised position to use it as a staging area.
Post pictures as you go or at least once it's done. :) John
/ Log Lift Table #6
my poor mans log lift, I normally do not have a lot of large rounds,
/ Log Lift Table #7
How does the lift crane turn from one position to another? Is it on a flange or just one piece of round tube that fits into another?
/ Log Lift Table #8
I have one of those HF cranes in my truck bed, and have been thinking about getting another to mount either on the splitter or on the tongue of our trailer.
If his is like mine, the bottom tube is reduced in diameter about 2/3rds of the way up to allow the top tube to fit over it. There is a grease zerk on the top of the top piece to help keep it rotating smoothly.
We also smeared some grease around the base to keep it smoother.
As is usually the case around our place, we have at times seriously overloaded the heck out of the truck crane and it has laways worked smoothly and making any movement from lifting, jacking it up or rotating it very easy.
Seeing your setup is really making me think again about putting it on
Thomas
No matter where you go; there you are...
/ Log Lift Table #9
Double post deleted
Would you mind awfully posting some detailed pics of how you mounted the crane to your splitter?
I would love some better idea how to get the mounting stiff enough to resist torquing it out.
On our truck we have support struts welded to the frame to stiffen it up.
/ Log Lift Table #10
My splitter has the outflow of the splitter valve plumbed into the inlet of the lift valve. I know this may not be the best way but i have had no problems as of yet.
/ Log Lift Table #11
about the best two photos that show the base, the splitter started out as a three point unit ran off the tractor Hydraulics, and welded a plate to the three point frame, and mounted the HF crane on it,
the unit was only about $130 and shipping I think was only $6 on it, the log grapple is from northern and was about $30, do not remember the shipping, but had that for loading the rounds, as I have another HF crane on the S10, and my grand son likes to help reel them in,
just for info the power pack is removable for other uses, (use it on the wire roller, have used it to run hydraulic on machine with out the tractor, have used it on other wire type roller for rolling up cable, and can still be used on the three point if needed, built the power pack after fuel got expensive, and my SIL need it one time so that is when the axle and tires were added,
/ Log Lift Table #12
Thanks for the pics that's a pretty neat setup I can see something like that in my future pretty soon me old back ain't what it used to be and needs all the help it can get.
/ Log Lift Table #13
You might be able to get one of those 2000 pound winches from HF and mount on your setup. It looks like they are on sale again for $59.99. Then you wouldn't even have to do any cranking.
12V Winch - ATV/UTV Winch with Load-Holding Brake
/ Log Lift Table #14
The least costly method for a log lift attachment is to use a electric winch. This one is self supported.
100 0123 - YouTube
/ Log Lift Table #15
Nice setup, but I've always thought the manual jack on those would be slow and tiring to use. You've got a hydraulic pump right there for the splitter - why not add another valve (with relief) and replace the jack with a hyd cylinder? Then you can use the hydraulics to run it faster and easier than it is now. Or perhaps you use the winch for most of the lifting and the jack isn't a big deal? I still think that you have hydraulics right there, it's a shame not to use them to the fullest...
Miller Millermatic 212 Auto-Set MIG welder (A63118)
Miller Millermatic...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
2001 John Deere 1780 Planter (A63109)
2001 John Deere...
UNUSED ATS EJ 11000 ELEC.JACK (A62131)
UNUSED ATS EJ...
2014 Econoline Trailers 29ft. 17 Ton T/A Dovetail Equipment Trailer (A61568)
2014 Econoline...
