kubota engines who makes them
/ kubota engines who makes them #1
case245
pa
kubota 7040sud
i have a 7040 it has a mitsubitsu belt on it same with starter does kubota use there engine in there tractor the injector pump looks like a mit pump
/ kubota engines who makes them #2
While Kubota manufactures tractors, I wouldn't imagine that they made the belts, hoses, starter motors, etc... Even if these parts were labeled Kubota - I would think they were probably outsourced and just stamped 'Kubota'. The same could even be true for the injector pump.
/ kubota engines who makes them #3
Engine is made by Kubota.
Accessories/consumables are made by suppliers.
/ kubota engines who makes them #4
:thumbsup:
And in case you were wondering, they probabally didnt manufacture the electric wire, hoses, nuts and bolts, battery, alternator, or miscellaneous fittings either.:rolleyes:
/ kubota engines who makes them #5
:thumbsup:
Are you sure about the nuts?:eek:
LD1 u need a baby rattle
/ kubota engines who makes them #7
And for that matter, a number of Kubota air filters, both inner and outer, are the same as other makers.
My JD 790 and Kubota L4300 air filters interchange,
/ kubota engines who makes them #8
I think that should be the other way around.
And I could be wrong, but I think most would tend to agree with me on that.
LD1 you dont know me nor does no one else on here you have no idea of my background before you judge learn the facts about a person i been on tractors back hoes dozers along time
/ kubota engines who makes them #10
The motor in my old B8200 was used in generator, and sailboats. A friend has a Bobcat S185 skidsteer; it has a turbo-Kubota in it. Kubota makes their own motors, and sources them to a lot of other companies.
/ kubota engines who makes them #11
I had a Yanmar engine in my sailboat. Deere uses the same one in their tractors. Years ago IH used to change from Prestolite distributers to Delco and back, according to price. Sometimes mid year.
/ kubota engines who makes them #12
Mitsubishi makes a lot of components. I know they do a lot of starters and alternators that could show up on about anything. They are a pretty diverse company.
/ kubota engines who makes them #13
The ones we sail in club have been Universal, although I believe some of the bigger boats may have Yanmar. The Cal 31 we're taking out tomorrow has Universal.
Interesting side tangent....
Three of the boats in this club, have had the diesel motor removed when they needed work. Instead of reinstalling the diesel, they put batteries, controllers, and electric motors in them. The owner said it was a major project to get the diesel motors in/out, like it took days to swap a motor. The electric motors, take 1/2 hour to swap. Same for any components in the system. The three boats were identical Catalina 30's.
Bay Area Tradewinds Sailing School and Club Announces They Have Gone Electric
/ kubota engines who makes them #14
They must have short run times. I had a Catalina 32 w/27 hp Yanmar used about 1/2 gal/hr. You would need one heck of a battery bank if there was no wind for most of the day.
/ kubota engines who makes them #15
Who's judging who??
And you are right, I dont know you. But my comments are based on what I have witnessed in your 6 months and 287 posts on this forum. And it seems about every week you have a new tedious complaint about kubota.
Remember this thread http://www.tractorbynet.com/forums/kubota-buying-pricing/255782-l-m-mx-series-can-4.html ?? It really started to get good on page 4.
And then on page 8 post # 72 of MINE, I suggest you get rid of your POS kubota and get anything other than a kubota. And low and behold, I now see you have your 7040 listed for sale in the private party ads section:confused2:
All I can say is...I am glad you are taking my advise.:laughing:
/ kubota engines who makes them #16
They run for at least a couple hours. More than enough to get on to the Bay from the Marina. But I would not try to make a run up the Delta(we sail from Richmond, Ca on San Francisco Bay).
They do have a pretty big battery bank.
/ kubota engines who makes them #17
The engine in my Bobcat 325 mini excavator is a Kubota. Very reliable, starts and runs strong every time.
/ kubota engines who makes them #18
Above is the short answer to the original question without all the snipping and sidetracking. Kubota makes their own engines. And as Ace3 pointed out, for equipment brands other than their own.
My Bobcat's got a 61 HP Kubota turbo in it.
/ kubota engines who makes them #19
I'm trying to figure out if I can put one in a hot rod.
2002 TRAVIS 39' FRAMELESS ALUMINUM DUMP TRAILER (A63290)
2002 TRAVIS 39'...
Arrow Quip 10' Heavy Duty Bow Gate (A64047)
Arrow Quip 10'...
2 PRONG HAY SPEAR (A63290)
2 PRONG HAY SPEAR...
2012 Gehl DL11-55 11,000lb. 4x4 Rough Terrain Telehandler (A61572)
2012 Gehl DL11-55...
Mini Excavator Grapple (A62183)
Mini Excavator...
2018 Deere 204L (A62180)
2018 Deere 204L...
