Finally got around to checking the rim bolts on my P 7010
   / Finally got around to checking the rim bolts on my P 7010
'the fact that it broke the mounting bracket when using the drawbar with a 3/8" chain and didnt hurt the chain shows a weak connection. Even though I was in 4 WD and all 4 unloaded tires spinning it shouldnt have broke even when the tractor hopped up and down before I could clutch it. That should be the strongest pull point on the tractor. It has this massive drawbar but is held by a piece of cast steel affixed with 2 each 10.8 grade bolts. I dont know the diameter offhand but the socket that fits them is 26mm so I am guessing about 19mm bolt diameter.
   / Finally got around to checking the rim bolts on my P 7010 #22
I had my LS in for some warranty work on the loader valve. It was the second time in, first they said they found nothing wrong - but I could duplicate the issue. Milling around and bullshirting with the mechanic. He was working on a similar LS to mine. Scattered all over, trying to get the broken loader mount bolts out, casting welded, tapping threads. This got me to check mine as soon as I got it home. Several needed to be tightened to meet torque. Only one was significantly loose. Be sure to check them! I would have hated for that to be my tractor being worked on!!
   / Finally got around to checking the rim bolts on my P 7010 #23
When you guts are testing and torking down these loader bolts why don't you take them out and put some lock-tite on them?
Well in my case, the one that was very loose is so far up behind the FEL support bracket and fuel tank that I could barely get my wrench in to it. I dont know if I could get my hand in there to put the bolt in without removing the fuel tank and then again laziness might be part of the issue. I guess a 5 minute check every 50 hours beats several hours of work removing and reinstalling the bolts. The issue being that I am not sure they were properly tightened to start with rather than them backing out. Now that I know they are as tight as I could get them with a 3/4" drive ratchet and socket, if they get loose again, the Loctite might be the answer. Now the one behind the fuel tank and FEL bracket, if and when I replace the fuel tank with the new one, that would be a good time to Loctite those and tighten H*** out of them.
   / Finally got around to checking the rim bolts on my P 7010 #27
Anyone know what the proper torque is on the wheel bolts on an R3039? Asked the dealer a while back but he couldn't find it in his manual. Thanks.
   / Finally got around to checking the rim bolts on my P 7010 #28
I was wondering about that one myself, Joe. No mention of wheel torque in the manual.
   / Finally got around to checking the rim bolts on my P 7010 #29
I don't have the same tractor, but I'm in the ballpark. Mine are 160 ft-lb for the rears, 62 for the front bolts, and 50 for the front nuts.
   / Finally got around to checking the rim bolts on my P 7010 #30
Thanks for the info. I will try those numbers.
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58214)
2011 NORAM POWER...
2007 Hyundai Santa Fe SUV (A55973)
2007 Hyundai Santa...
2015 NISSAN Pathfinder (A56859)
2015 NISSAN...
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2014 VOLVO VHD DAYCAB (A58214)
2014 VOLVO VHD...
