Loader Replacing FEL controls with Aftermarket - double or single stick
/ Replacing FEL controls with Aftermarket - double or single stick #1
dtperk
Ohio
Yanmar 336D / YFL-1500
Hey group,
WITHOUT getting into plumbing this way/that way, power Beyond / tanks, rear 3pt or ANY OF THAT, I would like to know who has had success upgrading/replacing the FACTORY FEL double stick control lever on a YANMAR FEL with an after market stick(s).
Quick background - Unit is a factory YFL-1500 on a 336D. The model year is 1986 (NOT grey market). My tractor did (at one point) have a factory backhoe (model unknown) at one point and had the 3 stick controls mounted to the rear fender.
Again, I don't want to get into how to plumb as eveything on my unit is working as needed. I am seeing a lot of use/wear on the cylinders that control my FEL and heim joints, so I would like to be proactive and swap out the control valve assembly before I have problems.
I know there have to be some of you that have done this type of - upgrade. I would like to keep the single lever setup, but get the better performance of 'moderized' control. I know the replacement needs to be open center and have been looking across some Prince brand valve bodies/controls.
Has ANYONE done this conversion successfully with a dual action, dual cylinder FEL? If it helps with a recommendation, I have 4 lines that run the cylinders on the FEL. Naturally, I have a feed and return line to/from the pump. Recommendations please!!! Thanks in advance gang.
DTP
/ Replacing FEL controls with Aftermarket - double or single stick #2
Close - but not exactly what you want to hear - I had an aftermarket (Hymari) FEL on a YM1500 which I have transplanted onto a FX24D - of similar vintage. The original cheap chinese block wore out, and started to alarmingly drop the bucket instead of slowly dumping. I replaced the valve body with a similar shape (unknown brand - sorry - but Im UK not USA) body, and transplanted the dual controls over too. dual vs twin levers isnt much of an issue - as the hydraulics are identical in my case, it is just a clever mechanism under the rubber boot.
/ Replacing FEL controls with Aftermarket - double or single stick #3
Make sure the replacement has 'float' when you push the lever beyond 'down'. I've read that some Chinese loaders don't have this and its not universal among replacement controllers. The ability to smooth out spoils by floating the bucket in reverse is an important capability.
/ Replacing FEL controls with Aftermarket - double or single stick #4
Yes you can swap out the controls. Just be sure to use the correct valve style for your tractor. be it open or closed center. I noticed on the Prince LVT series they have severl options for spool configurations while on the "Brand" loader valve you can only get float on the second spool which would give the bucket top priority.
Roy
/ Replacing FEL controls with Aftermarket - double or single stick #5
I have replaced the OEM loader valve on one of my machines with a replacement valve. It was straightforward, but bothersome because the valve I found that fit my budget ($35 or something stupidly cheap like that) had a different bolt pattern than my original valve. I don't have any real recommendation. Buy a decent valve of the proper size and bolt pattern, and with the same size and arrangement of ports. The only tip I would have is to clean everything very thoroughly BEFORE you disassemble things. Otherwise it is simple and mine works just fine.
/ Replacing FEL controls with Aftermarket - double or single stick #6
$35 valve? Where?
I'll figure out a mount for $150~$200 of savings.
/ Replacing FEL controls with Aftermarket - double or single stick #8
That was exactly my thought. I found it on Craigslist, a New Old Stock unit from a warehouse being liquidated. They only had one, but it was enough of a bargain that I have nothing to gripe about.
However, it does not have a float position. This is not really a bad thing for my purposes, but it does hinder the ability, as California said, to gently smooth a surface. I would second his suggestion to verify the type of loader valve control you want. It's a simple procedure to swap, but a set of very thin wrenches was very helpful to me in removing the fittings.
Great input everyone! Thank you.
@Guyd - Thank you as well for the input. Exactly as I am approaching this 'upgrade' - - Similar shape size and looking to minimize the 'clever mechanisms' under the boot :) Cheers!
@Oldnslo - I agree, Several different options for the Prince line; and YES, get the correct config on the body to meet my 336 needs. I do have PBY off the current loader valve body that runs back to the rear stick body that ran the no-longer existent back hoe. Newer lines had all been put in, have quick disconnects on the fender to fab up some home-brew tools (maybe log splitter, etc) - but didn't want to open that can of worms with this post.
@California - Great tip about the 'FLOAT' feature! This I would have overlooked. Thank you!
@ 284 - Always try to keep the system clean! Don't need 'junk' floating through the lines - You guys might think I'm crazy, but my tractor is actually garaged and my secondary vehicle sits outside - Heck, My tractor and a few high $$$ implements are worth more than my old F250! lol!
@aczlan - Agreed - Wish I would run up on a deal for $35!!! I know this will be a 2-300$$ job. Plus probably some adapter fittings, etc. But I'm sure after the 'upgrade' is done, I will have a much better control 'system' and better response from the FEL. My unit pulls dual-duty as the main 'yard' machine, but I'm also using it for loading/unloading pallets more and more often. A smoother valve body would give me the assurance I am also looking for when dropping pallets full of product on the back of a Semi. Don't need an insurance claim if I can help it! :) LOL.
Thanks gang for all the great input / ideas - so if anyone finds a deal like 284 did on a two-cylinder body LEMME KNOW!!! :) I need an open-center body with power-beyond port and now am looking for the float feature.
DTP
She ain't pretty, but a darn work horse! I love my tractor! :)
/ Replacing FEL controls with Aftermarket - double or single stick #10
Nice pictures, I like the muffler patch. :D
Awe Thanks Winston - Yer just jealous..... Gotta love pop rivets! :thumbsup: :thumbsup: :cool:
/ Replacing FEL controls with Aftermarket - double or single stick #12
If you mainly want to slow down the "drop", you might try something like: Surplus Center - 3/8 NPT 8 GPM PRINCE WFC-600 IN-LINE FLOW CONTROL on the "Lift" line. That will allow full flow up and let you slow down the drop rate.
Aaron Z
Isn't it 'common' on most FEL controls (at least late model FELs) that most of the actions are dual speed?? I.e. - half stick for lift is 'slow' and full stick lift is 'fast'? On my 336/1500 FEL, seems as though two of the actions operate that way, but the opposite two do not - which leads me to believe that a newer body/assembly may restore or give me that desired effect/operation. - Maybe I'm off base in my thinking - - I am not a trained heavy equipment operator!
/ Replacing FEL controls with Aftermarket - double or single stick #14
I don't know about most but the joystick on my foreign made Bulldog loader will control whatever speed you want from barely to gettin it. Only drawback is it doesn't have the float that California mentioned.
/ Replacing FEL controls with Aftermarket - double or single stick #15
Not much going on in this forum so I'll share a photo I just took.
This illustrates how backdragging the bucket in 'float' position does a nice job of levelling uneven ground.
I had taken out a dead tree and needed to level out the whole area.
I made parallel passes uphill (toward camera) then a couple of passes side to side to make the ground transition evenly to the driveway (foreground).
There's not much to see here, and that's the point. I couldn't make the ground this smooth, if I didn't have 'float' to let the bucket slide along the ground independent of the tractor's lurches as it backed over lumps and hollows.
/ Replacing FEL controls with Aftermarket - double or single stick #16
Nice pic California and looks like a good job too!
My Koyker 160 1 stick with float, the float doesn't work like its supposed to if I hit a bump it will kick out and go to fixed position. And I say that with having JD and Cat and Case loader experience they will stay in float as long as you have the lever in detent going forwards or backwards. fwtw.
fwtw I need to hold it forward if I want float and with the way Koyker tech dept acts when called I am going to forget about getting help and live with it and just buy another brand loader next time. That and this also may be a result of my particular loader valve being in series w/3 pt also with no power beyond in place yet? (project for later) elifino
/ Replacing FEL controls with Aftermarket - double or single stick #17
My loader valve will kick off float position at times. I don't think it has anything to do with the way your;s is plumbed. I have a problem with the small nuts working loose inside the valve. I'm going to purchase a prince loader valve (at some point) & see if it;s any better
/ Replacing FEL controls with Aftermarket - double or single stick #18
Mine will kick out of float but I assume the 30+ year old detent is worn. Maybe I should rig a wire loop to hold it in float while I steer driving backward.
Apparently due to wear, and more of a nuisance: backpressure while the 3-point is raised carrying a heavy implement, can flow back through the loader's valves if they aren't perfectly centered. This can cause unintended lift or curl. I closed the Service Valve (not recommended) to have precise control of the loader for the smoothing in that photo.
/ Replacing FEL controls with Aftermarket - double or single stick #19
As I remember it, for some reason we had nothing but problems with the OEM joy-stick on our '83 JD 950 with FEL. I built a bracket and mounted a new two-handled control block in 1991. Haven't had any problems since then.
/ Replacing FEL controls with Aftermarket - double or single stick #20
I have had imo nothing but trouble with my OE joystick from minute one its been anything but a joy. :laughing: For instance it wont curl down 80% of the time and the float issue. I will be definitely interested to know if anyone comes up with a valve that actually works like it should. I really dont want a 2 stick if I can reasonably get around it I have used 1 stick valves that do work fwtw.
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
Tafe 45DI (A60462)
Tafe 45DI (A60462)
2013 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR2DJ296618 (A61165)
2013 International...
Kubota RTV X1140 (A60462)
Kubota RTV X1140...
IRANCH 80CM HYDRAULIC TILTING BUCKET (A60736)
IRANCH 80CM...
yellow ball Trailer (A56859)
yellow ball...
