Compact Tractor Rake Grapple that does not need Aux Hydraulics to work
   / Compact Tractor Rake Grapple that does not need Aux Hydraulics to work #1
fleetman1979
Cleveland, GA
New Holland TC35D
I am wondering if there is a grapple rake for a under 50hp compact tractor that can open and close itself by using the tilt cylinders on the loader. I am just looking for something that can grapple brush without the need of the $900 hydraulic kit. Does anyone know of anything.
Brian
   / Compact Tractor Rake Grapple that does not need Aux Hydraulics to work #2
Brian
Why not just use your rear remotes and lever? All you'd need are the hoses.
   / Compact Tractor Rake Grapple that does not need Aux Hydraulics to work #3
Do a search for BX25 GrappleOmatic
   / Compact Tractor Rake Grapple that does not need Aux Hydraulics to work #4
   / Compact Tractor Rake Grapple that does not need Aux Hydraulics to work #5
Yes - we make a mechanical Brush Crusher (BC-3000) that will open and close of the tilt cylinders. They work great and were designed specifically for you limited hydraulic set up. VIDEO
   / Compact Tractor Rake Grapple that does not need Aux Hydraulics to work #6
2003 Big Tex 10PI...
2018 HINO CONVENTIONAL TYPE TRUCK (A58214)
2018 HINO...
2019 Ford Escape S SUV (A55853)
2019 Ford Escape S...
2016 TRAILSTAR 40FT DUMP TRAILER (A56129)
2016 TRAILSTAR...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
Adams 6 Ton Hydraulic Lime Spreader (A55315)
Adams 6 Ton...
