BX Radiator drain pigtail
/ BX Radiator drain pigtail #1
RobertCramer
Western Mass
I just put a short lenght of tubing on to the drain nipple on the bottom of my BX radiator and ran it thru the frame a bit to a valve on the other end. I will now never have to go thru the painful flushing of the radiator again. This makes it very easy.
Bob
/ BX Radiator drain pigtail #2
Great idea that I may implement. I'm due for another flush/fill myself but for now, I will stick with what I did last time by removing the lower radiator hose and removing the undocumented block plug.
/ BX Radiator drain pigtail #3
You can do the same thing on your car too.
/ BX Radiator drain pigtail #4
Can someone point out where this undocumented plug is - in the middle of changing antifreeze on my bx2360 as we speak!
/ BX Radiator drain pigtail #5
I just looked at mine and did not see a drain. The bottom radiator hose would be the easiest way to drain it, just don't give yourself a bath.
/ BX Radiator drain pigtail #7
That has been undone. Will that drain the system sufficiently?
That will drain the rad completely but there will still be some in the block. I don't see a drain on the block. You may want to flush the rad with some water. Be sure you purge the system when you refill it.
/ BX Radiator drain pigtail #8
/ BX Radiator drain pigtail #9
Thanks. It is too late :) I added about 1 gallon 50/50 Fleet Charge from TSC and distilled water. There was some green coolant left, from the block obviously. I will check using a test strip and adjust accordingly.
/ BX Radiator drain pigtail #10
Sorry I did not see it. I was running out to the building looking for it but with the side panel on it is hard to see.
Lincoln DC-DC 600 Commercial Welder (A62183)
Lincoln DC-DC 600...
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
Iranch High-End Electric Tricycle (A62183)
Iranch High-End...
2017 Nissan Sentra SR Sedan (A61574)
2017 Nissan Sentra...
2015 Bobcat S750 High Flow Rubber Tire Skid Steer (A64047)
2015 Bobcat S750...
2021 TAKEUCHI TL12V2 SKID STEER (A63290)
2021 TAKEUCHI...
