Husqy 435 Cutting "on a curve"
   / Husqy 435 Cutting "on a curve" #11
I agree with those who say get a new chain.
A new chain shouldnt be mroe than $15. But if thhe chain you have is "managable", save it and use it next time you are cutting a stump. Once that is done, put your new chain back on.
   / Husqy 435 Cutting "on a curve" #12
Its the chain I can almost guarantee it you can flip the bar and prove if its the bar but I highly doubt its anything but a dull or incorrectly ground chain btdt. hth
   / Husqy 435 Cutting "on a curve" #15
I was going to say that the Husky was just trying to get away from the Stihl, so set the Stihl to the other side. Seriously, if t was anything besides the chain, I would be surprised.
:D
Now, I need to actually find one. They're darn near impossible to find in stock around here, and trying to figure out which one to order is way more complicated than it should be.
Just for the sheer simplicity of it, I am seriously considering selling the Husqy outright and buying a new Stihl MS250 with an 18" bar. It's just a tad heavier than the Husqy but with way more power and uses the exact same chain and bar as the MS290. The 290 is heavier and more powerful for those long days of cutting, but the 250 would work just fine as a backup to it if I needed it. And, selling the Husqy would cover a good portion of the cost of a new Stihl.
   / Husqy 435 Cutting "on a curve" #17
There are a lot of people that like the MS250 Stihl. My main saws are a 026 and MS441 Stihls, but I also have a Stihl MS192T that I bought for light limbing and to keep in the garage for branches and trees that fall down around the house, but it has made it into the back of my truck and I use it a surprising amount. It is listed as a pro saw, but it is really made of homeowner components. Had I known I would use that top handle configuration as much as I do, I would have bought the MS200T, but the little 192 works well.
Homeowner saws can be just fine for many people that use their saws on weekends or a few times a month. I am looking to upgrade my 026 to the MS261 but if I used that saw less, I would have no problem with the MS250. Someone told me once that Stihl had only really two grades of saws, professional and everything else. If that is true then a MS250 would be of the same quality as your 290.
Local dealer had initially recommend the 180 and 192 CE. I told him that I didn't want the "quick adjust" chain tensioner on the 180 and saw no reason to spend extra on the easy start system of the 192 when I can easily start my 290 without any "help". Also, the Easy Start system adds cost to some repairs... So, why have to learn how to start two saws in very different ways at more expense?
From there, the conversation went very quickly to the 250 as a great alternative. Very similar to the 290 in so many ways, including using the same .325 chains. He said that if I can start my 290 with no issues, the 250 would be a breeze.
Is the 251 the Wood Boss? If so, I was looking at that one too. Excellent looking piece of equipment, but overkill for my needs (heavy compared to the 250 and I want to be able to use it for limbing work).
   / Husqy 435 Cutting "on a curve" #19
The MS271 (3.49hp) is the Wood Boss I would think that is too close to your MS290 (3.8hp). You want some difference between saws so you can use one or the other depending on the task, so If it were me I would choose the MS250 (3 HP). You are right about the difference from saw to saw in starting them or needing to shut them off in a hurry. It is nice to have the levers in the same spot. Having 10 tractors I often have to look down to see which one I am on before changing speeds and saws are kind of the same.
Yes... 271 - that's the one I was thinking of. Too close to what I have (as is the 291). The 261 looks to be a very close cousin to my 290 but in the next grade up. My understanding is that the pro grade saws have some metal where the homeowner / farm saws are plastic (like the lower body housing) making them tougher. Also, there are one or two mechanical components that are a little stronger. Otherwise, very similar. Basically, the pro grade saws are built to be abused more.
2022 John Deere 5065E MFWD Tractor (A53485)
2022 John Deere...
Portable Restroom (A54865)
Portable Restroom...
2005 INTERNATIONAL DURASTAR 4400 24FT BOX TRUCK WITH LIFT AXLE (A56138)
2005 INTERNATIONAL...
2005 Military Trailer (A53424)
2005 Military...
Engel 20' Boat (A50121)
Engel 20' Boat...
