C4005 pto dropping out when bush hog engaged
/ C4005 pto dropping out when bush hog engaged #1
hose6161
lone star, texas
c4005-di
I am considering buying a 650 hr C4005-DI with FEL. I told the seller I also wanted a bush hog since that's mainly what I will be using it for. He just called me and said when he hooked up the used $900 bush hog, the pto keeps dropping out so he took it to his tractor repair person to troubleshoot/repair. My question is should I bail out of this purchase?
/ C4005 pto dropping out when bush hog engaged #2
I'm not sure what "dropping out" means...does it just stop? Is the 4005 an independent PTO? If so it sounds like the PTO clutch is shot...if so, a new complete clutch "pack" would need to be installed...meaning splitting the tractor...let us know what the guy says..BobG in VA
The PTO shifter bracket shaft was broke. It wasn't keeping the gear engaged. They replaced it .
/ C4005 pto dropping out when bush hog engaged #4
Did they have to open the tractor in two or is this a fix from the outside and how much did it cost?
Coats 5060AX Rim Clamp (A61307)
Coats 5060AX Rim...
2014 Timpte Hopper Bottom (A61307)
2014 Timpte Hopper...
KUBOTA M9000 UTILITY SPECIAL TRACTOR (A59823)
KUBOTA M9000...
2000 GMC C7500 (A60736)
2000 GMC C7500...
FENCE PANELS (A58214)
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
