Rotary Cutter Lubricant leaked from Bush Hog Rotary Cutter
   / Lubricant leaked from Bush Hog Rotary Cutter #1
Batman50615
Center, MO
Ferguson 20
Have on old Bush Hog Rotary Cutter Model 105 Serial # 30964. The lubricant leaked from the gearbox and comes out from underneath. What do I need to do to fix? Where can I find instructions on how to repair? What is the correct lubricant to put back in once it is fixed? To what level do I refill the lubricant once it is fixed?
   / Lubricant leaked from Bush Hog Rotary Cutter #2
It is the output shaft seal. You can put cornhead grease or even std NLGI 2 in it and just keep running it for many years. Fixing it will require taking it apart ... time, tools, and skill. And it might go bad again ... quickly or not. :confused3:
larry
Sorry, but I'm not real mechanical. What is cornhead grease & std NLGI 2? Maybe a brand name & viscosity rating or something that would help me pick the right thing from a Farm & Home Store.
   / Lubricant leaked from Bush Hog Rotary Cutter #4
I just pumped mine full of bearing grease that I use for all the grease zerks on the equipment. Has worked for several years w/o issue.
   / Lubricant leaked from Bush Hog Rotary Cutter #5
Same here, sep'n mine was full of grease when I bought it. I ran mine that way for five years and sold it (just didn't need a bush hog anymore). I'm sure the new owner will run it for many more years with the gearbox filled with grease.
   / Lubricant leaked from Bush Hog Rotary Cutter #6
It's really not hard to fix, but the parts are heavy and require large tools. If there is any wobble at all it oblongs the seal and they leak. I replaced my seal twice before giving up and filling with grease too
   / Lubricant leaked from Bush Hog Rotary Cutter #7
could just be the seal.. or could be a bad bearing.
it's worth checking.
if it does not leak fast on 80w90 gear oil.. go with a 0 EP grease jd cornhead grease is 0 ep. lubes like snapper/stens make a 00ep grease for lawn/golf course maint equipment as well.
checkt hhat bearing though.. if bearing is bad.. it will eat seals,, and leak worse till it flies apart..
   / Lubricant leaked from Bush Hog Rotary Cutter #8
If you go to a tractor dealership (especially a JD one) they should have 'cornhead' grease -
John Deere Special-Purpose Corn Head Gun Grease - AN102562
its thick enough that it wont reach a melting point and leak past the seals..
Brian
   / Lubricant leaked from Bush Hog Rotary Cutter #9
I have an old Bush Hog 13' flat rotary cutter. The outboard seal was leaking BAD on mine so I replaced it. The hardest part was getting the stump jumper off. We ended up cutting a hole in the deck and sliding a large solid bar down thru the hole to the topside of the stump jumper and then pounding on the bar with a 16 pound sledge, we also applied heat. Wow, it was a tough bird to remove.
Once it was off, piece of cake to replace the seal. And the seal was only around 10 bucks if I recall.
As far as quantity of oil, the two out board hubs on mine have a 1/4" "fill to this level plug" that when oil runs out - it is full. The center hub just has a fill opening part way up on the gearbox, and you put oil in it until it starts to run out the same hole. Pretty simple. I use 90wt gear oil, but then my seals are in pretty decent shape.
Ditto what has been said re: checking the bearings and the grease if your seals are leakers.
   / Lubricant leaked from Bush Hog Rotary Cutter #10
Try Cornhead grease first. Two tubes are about $10. It takes 15 min. to fill it up. Way easier than a seal. Cornhead grease thins more atr heat to act like the regular lube. I don't understand why it does not come from the factory with it.
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
2008 Ford Focus SEL Sedan (A54815)
2008 Ford Focus...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
12-Ton Hydraulic Bottle Jack (A55852)
12-Ton Hydraulic...
2019 Autocar ACX Xpeditor T/A EZ-Pack Front Loader Garbage Truck (A55852)
2019 Autocar ACX...
