Hill problems
/ Hill problems #1
yanmars
I have a manual front wheel assist Mahindra 4510 tractor. About 45 hp. When I am in 4 wheel drive going down a hill it wants to "freewheel" and gain so much speed the brakes will not hold it and I have to put the front end loader bucket down to slow it down so it does not get out of control. I am NOT pushing the clutch in.
The other problem, going uphill I barely have enough power/traction to get up the hill unless I also engage the rear wheel lock so both rears are locked and pulling. This is a recent occurrence, it never did this in the past.
The rear tires are over 60% and the fronts are slightly under 50%.
Any thoughts as to the problem? Thanks
/ Hill problems #2
I'm not sure about what is wrong with your tractor, just a guess, your clutch maybe going out or out of adjustment. But please be dambed carefull lowering your bucket going down hill! I can see all sorts of bad things happening, from flipping the tractor to tearing off the loader or much worse.
/ Hill problems #3
More detailed info will help.
Is it a power/engine braking problem like a badly slipping clutch (smell it burn ?) or super low compression (very hard to start ?). Can you hear engine reving up going down hill ?
Or is it a traction problem where it slides down hill and wheels slip going uphill?
Is you 4wd working correctly ?
/ Hill problems #4
Do you have a high/low range selector? Your uphill and downhill problems sound exactly like its in high range.
/ Hill problems #5
Since this is a recent problem is it possible you have had a failure in the rear diff? The diff lock could be powering around the failed component. I am not sure how the diff lock on your tractor works - there are different designs. I assume everything works okay when in 2 wheel drive so that rules out a completely failed drive train to one rear - the tractor would just sit there and not move. Another thing I was thinking of since you said this just started is something in the front wheel drive that is causing drag but that would not explain the loss of braking.
/ Hill problems
I had a new clutch and throw out bearing put in about 30 hours ago. This problem did not arise until I had it at the dealership after the new clutch and they had it for over 9 weeks and put 14 hours on the tractor. I am not sure what all the hours were for but I noticed the problem very soon after I had it back.
I am not saying it was related to that but that is when it occurred first. They cleaned the radiator, put in a thermostat, hoses, new coolant and a battery.
I do not hear any overrevving etc.
I "thought" it could be a clutch but that is so new but who knows.
/ Hill problems #7
The clutch can be new, but still do what you describe if it is slipping.
Have you checked to see if the 4WD is operating correctly?
/ Hill problems #8
A slipping clutch explains everything except why pressing the differential lock helps get up the hill. That I haven't got figured out . Are you sure it really helps? Is one tire spinning going up the hill? This part just doesnt make sense to me.
James K0UA
/ Hill problems #9
If a rear axle gear or shaft was broken/stripped, it could have similar symptoms. 4WD position would really be 2WD until the differential lock was used. When climbing, the rear power goes to the nonfunctional side until the lock is used.
You didn't mention what happens in 2WD.
Bruce
/ Hill problems #10
I couldn't figure out how using the diff lock would help if the problem was a slipping clutch. Logic would say it would make it worse. Example with my hydro - if I am in a condition where I need to use the diff lock, it lugs the engine down because of the extra power now being transmitted to a wheel that has traction. And if a clutch could transmit enough power to enable climbing a hill, why would it slip to the point of free wheeling on the way down? Why aren't all problems as easy to diagnose as, " Engine started to make noise so shut it down. Looked up front and there was a hole in the block and a bunch of parts mixed into a large pool of oil on the ground."
/ Hill problems #11
It sounds like the 4wd is not engaged. I would check this first.
/ Hill problems
The tractor is not here but at my farm some miles away. I will try a few things mentioned and report back as soon as I can. Thanks for the suggestions to date.
/ Hill problems
An update. I do not now "think" it is the clutch. I put it in high gear, set the brake and it stalled. I do not think then the clutch is slipping.
I lifted the front end of the tractor and put it in 4wd. The front tires did not turn so I "believe" the mfwd assist is not working. I had it stuck in my bog just a week ago and I could swear the front wheels spun/worked then. The 4wd is operated with a mechanical lever inside the cab that moves a rod that goes down outside the cab. I am thinking it is all mechanically operated but is there any electrical solenoid or contact to make the 4wd actually engage? Any help here is appreciated. I have my manuals and will try to check there.
I need the 4wd because of my hills. I have a Kawasaki Mule 2510 UTV. On some hills in 2wd and the differential locked it will not go up the hills until I put it in 4wd. The tractor is similar, I usually had it in 4wd all the time except if on the road or just on flat surfaces.
Any thoughts are appreciated. Thanks
/ Hill problems #14
It sounds like your front wheel assist isn't engaging. It could be as simple as the roll pin being sheared which holds the lever on to the shaft where it goes into the transmission.
/ Hill problems #15
No doubt about it, no front drive--i.e., not actually in 4wd. Downhill toboggan ride is because rears are unweighted, so brakes have no effect. Your front-in-the-air experiment confirms ...but, I would be careful doing it; didn't the rears move the tractor forward?? To get braking in 2wd downhill, need lots of weight on rear and empty or no bucket in front. Hopefully the rears are filled. If you have an implement --like a mower--on the 3ph, then it has to be raised (raised) to actually weight the rear tires ...so, if your sleigh ride downhill is with a 3ph implement, try raising it before you throw out the anchor (bucket down). The real answer is "get it repaired" ...(and get a rebate for those 14 hrs.)
/ Hill problems #16
How many hours on the tractor.......... what did you do to it that it needed a new clutch........ I have 3,000 hours on my Hesston 90 100 and it works hard all year long........ Gear tractor and the clutch works just fine.
/ Hill problems #17
OP said the tires were about 50% tread so I think ~2Khrs.
larry
/ Hill problems #18
I have a similar problem with a steep hill I mow. When I get to the top I close the the throttle all the way, don't touch the clutch or brakes and the engine slows the tractor nicely. This is a new machine with R4s. Why it dosen't slide on the tires I don't know. Oh, I'm still in 2wd.
/ Hill problems
The tractor has 1118 hours on it. I bought it used at 925 hours four years ago. How it was used before I do not know. What caused most of the problem is the throw out bearing fingers did not release and ground them off. The clutch itself was not too bad but once the tractor was separated a new clutch was added as that was not too expensive of a part.
/ Hill problems #20
Rear mower counterweight. Hill no more than about 22 degrees.
larry
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2022 EZ-GO ELITE...
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A64280)
2006 FORD F-450...
John Deere 2210 Field Cultivator 43' (A63688)
John Deere 2210...
