J_J
Super Star Member
- Joined
- Sep 6, 2003
- Messages
- 18,973
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
Your switch over on that 2 stage pump is about 600 psi.
Here are some details for your pump.
http://www.northerntool.com/images/downloads/manuals/1056.pdf
Look at first page.
Min HP to run that pump is about 8 HP according the chart.
I think you are running out of HP with that 5 HP engine.
Since the second stage on that pump is about 3.97 cu in, and at 3000 psi, Hp required is 8.
You can achieve 2000 psi with 5 HP and a cu in of 3.97.
So , what is happening is that when the pump gets to 2000 psi, it will stall the pump. If you had 8 HP, The pump is capable of producing up to 3000 psi, but the max relief on that valve is 2750 psi.
When you get your gage, check the relief.
You need to re-engine the splitter or replace the pump for a smaller GPM.
Look at first page.
