Post photos of your improvised tool box for your SCUT
   / Post photos of your improvised tool box for your SCUT #11
:applause: WOW :applause:
That is sweet. I would be afraid to put my chain or any sharp tools inside of that fearing I might actually scratch it.
Again, very nice fabrication.
Thank you very much. When I purchased our Kubota 5740 last year I fabricated a similar one for it but this time I went with a bumper/shackle center design with quad flash L.E.D. oval strobe lights in it. I use the FEL tubes for tow slings and they are kept in there by machined aluminum caps that I made. You'll notice the caps on the FEL, they are black. Never enough room on a tractor but this system works for me :thumbsup:
For the longer items I needed to carry I went with these rubber clamps and this is how it looks.
With my hands............SWMBO, drives the tractor:laughing:
I can't find the photo's right now, but if you have the ballast box.......which you should..........stand up pieces if 4 inch drain pipe , in the corners, before you fill the box with concrete. Instant tool holder
So... are you walking behind SWMBO?
I don't have a Ballast Box yet. I don't have anything on the front of the tractor. When I make one, I'll definitely put some drain pipe in the corners.
Maybe you could clamp a piece or 2 of pvc pipe to the Rops and slide the handles of the tools in there. For a toolbox on my 2520 I have been eyeballing the space between the rops behind the seat. Just need to find a box to fit there. I usually like to carry a putty knife, knife and a few hand tools when mowing around the farm. That baler twine sneaks up and wraps my blades and I have to cut it off. Went to net wrap last year, my twine problem is slowly going away.
I have a friend who put plastic pipe on the ROPS. I'd like to see some photos of other's installations. We have some great ideas in this community.
View attachment 279003View attachment 279004View attachment 279005View attachment 279007
Good morning,
This is what we did for our 2520. I wanted something that mounted behind the seat yet did not create an interference with the seat or the 3 pt arm. My preference would have been plastic but I found this generic metal toolbox at our local Fleet Farm.
I did paint the box as the green on it was closer to an Oliver green vs JD. Not a big deal. The installation was quite basic in that I used an existing hole on the rear frame and then similar to the extinguisher mounting, drilled a hole on the left hand side and used a #12 self tapping screw. Once it was secured to the frame, I added a rubber mat at the bottom for less rattle. I did need to add some washers/spacers on the SMV sign in order that there would be no interference with the opening and closing of the lid.
The toolbox measures 16 x 6 x 6. The main reason for the toolbox was to have a place for my chain, my Kubota tow strap and a few tools (channel locks, vice-grip, & screwdrivers).
I love what you did. I have less space between the SMV sign and the back of the seat than you do, but I could shift a box to the right side. Thanks for sending the info.
I dont know if you have a ballast box or not but as Don noted, we also carry our tools in PVC pipes installed in our ballast box
I don't have a FEL, but if I get one, I like the ideas I see on your ballast box.
Slightly bigger tractor, but this is what I have on my 790:
Plate w/ tubes for hammer & big screwdriver/prybar.
Ammo box clamped to loader frame.
Chain tray between grille guard uprights.
Ballast box has scrap iron in it, tray about 8" down from the top is old galvanized grainery door. chainsaw sleeve on one side & tubes for axe, shovel, rake, etc. on the other side.
Your chain tray on the front looks like something I could do. The frame in the front has room for 4 suitcase weights, but I don't usually have them on the tractor. I don't have a grille guard, so a tool box on the front frame would act like a bumper.
I don't have room for the other ideas, but I like them.
Pixguy - looking good! How much weight do you figure your ballast box will give you?
   / Post photos of your improvised tool box for your SCUT #18
I keep a rake, peevy, or iron bar in the loader torque tube or the grapple tube. My not so fancy tool box sits on a shelf I put across the fenders and supported by two pieces of light angle sandwiched on the rops
The pipes work great for shovels, etc. Don't forget drain holes in the bottom so water doesn't collect. Here's mine.
I like that hitch attached to the ballast box. Great idea!
4shorts -
Amazing!!! That latching system is sweet.
2012 WESTERN STAR  4900 SB INOPERABLE (A58214)
2012 WESTERN STAR...
POULAN CHAINSAW, BLOWER, (3) WEEDEATERS (A58374)
POULAN CHAINSAW...
CYCLE KNIVES (A58374)
(2) 18.4-38 DUALS ON 10 HOLE JOHN DEERE RIMS (A52708)
(2) 18.4-38 DUALS...
AMCO F15B 48 BLADE FOLDING DISC (A52708)
AMCO F15B 48 BLADE...
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
