Power Plug install photos for Murphy1244
   / Power Plug install photos for Murphy1244 #11
yeah for some reason the auto-focus did not work very well on a couple of those, but it is the standard 2 prong connector like a 4 prong trailer connector, with the ground the exposed connector and the positive encased in rubber and there is a tethered plug of rubber to plug into it to make it water resistant.
James K0UA
Thanks James, I am going to install the power point plug in the right side of the machine just below the lided storage compartment.Any idea as to what to use for drilling that hole without destroying the panel?
I dunno.. but my lidded storage compartment is on the machines left side and is made out of some kind of hard plastic,, I suppose maybe ABS or something, I have never tried to drill it. But if I had to drill it, I would probably try a step bit and not push too hard. Are you thinking about putting in a female cigarette lighter plug?
James K0UA
   / Power Plug install photos for Murphy1244 #13
James K0UA
Yes, a plug so I can use a lot of accessories like my sprayer and spot light. My draft and positioning controls are on my right.
2019 GALYEAN...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A56129)
2016 INTERNATIONAL...
5011 Ford F-550 (A55973)
5011 Ford F-550...
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
Toro z turn (A56857)
