Oil & Fuel trouble starting engine
/ trouble starting engine #1
bcinlittleaxe
Member
little axe,ok
mahindra 4500
I have a 2007 Mahindra 4500 2wd that quit on me , I replaced the fuel filters on it and have bleed the system many times now and still can not get it to start. can anyone tell me what else to do or try.
thanks
/ trouble starting engine #2
This may sound a little crazy, but the banjo coupling into the injection system (line from the tank to the injection system) may have a clog in it where it goes into the injection syst. take the bolt loose and see if you have good fuel flow, if not run a wire into the line (back towards the tank)...see it that helps, if not, back blow with a compressor on it till you hear bubbles in the tank(take the fuel cap off first)...Hope this helps...I replaced fuel filters on my 6000 and it was the above,,, once I took the line loose, just a small flow came out...when I hit it with the air hose...mucho fuel started coming out...be ready to turn off the fuel at the tank...BobG in VA
/ trouble starting engine #3
In case you don't have an owners manual, you might need to drain the fuel tank at least once or more in the tractor's lifetime. It could be possible there is a clog in the bottom. Are you getting fuel to the injectors?
yes I am getting fuel to the injectors, but I may not be getting enough. Thanks for the tips, I will try this tomorrow
/ trouble starting engine #5
One other item....how did it act when it quit?? If your injection pump/cam for valves, etc, has gotten off timing, it would act that way even if you were getting fuel..Do you get smoke out of the exhaust when you try to start it?? BobG in VA
at first it just quit running (just died) then after letting it sit for awhile it would start and run for up to about 1 minute or so. now it wont even try to start, i`m going try blowing back the line here in awhile, and yes i did get some smoke when trying to start it
/ trouble starting engine #7
Check your air intake. It sounds like it could be a badly clogged filter.
I blew back the fuel line from the filters back to the tank and it started right up. wish i had known this the other day, would have saved me alot of work. Thanks Bob G
/ trouble starting engine #9
Wooooo Hooooo! Another satisfied customer...BobG in VA
2025 Landhonor BS-12-2500G Bale Spear Skid Steer Attachment (A60353)
2025 Landhonor...
(APPROX,9) UNUSED KJ GALVANIZED WELDED WIRE MESH (A62131)
(APPROX,9) UNUSED...
2006 Mercedes-Benz Unimog 405 4x4 Flatbed Truck (A56858)
2006 Mercedes-Benz...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A61568)
2018 Ford F-150...
UNUSED FUTURE FT-X39 MINI HYD TRENCHER (A62130)
UNUSED FUTURE...
2018 Peterbilt 579 Sleeper 72" Sleeper (A62613)
2018 Peterbilt 579...
