Losing pins off the back of the tractor
   / Losing pins off the back of the tractor #21
All joking about money aside, I don't actually understand what you mean. The problem with the spring-type pins is obvious: weeds pull them out. But the split-type pins seem pretty secure to me. How are they going to come out?
Cotter pins are too soft to last imo. I buy the black lynch pins from Tractor Supply for .99 each way stronger spring and haven't ever lost one of these. You can also buy some of the smaller sizes for replacement of the smaller hairpin clips. These black lynch pins are tough so don't get your fingers in the way when you latch them.
They'll still pull out.. They just require more force before they do. Also, the bent ends of the pins can get caught and "straightened", making them fall out.
But... I just spent, like, two dollars on a hundred of them! Are you telling me it's all for nothing?!
   / Losing pins off the back of the tractor #23
Sell 'em for scrap. Throw 'em in the ballast box. Give 'em to the wife and tell her they're new hair pins. Lots of uses for them still.
You're right. I don't have a ballast box, but I duct-taped them to my drawbar, and the ride on my tractor is MUCH better. I can't believe I never thought of this before.
   / Losing pins off the back of the tractor #25
   / Losing pins off the back of the tractor #26
It's true, but for the price of 1 locking lynch pin, I can buy 100 split cotter pins. Meh. It's not a perfect comparison, because I only need about six locking lynch pins. More fundamentally, I already bought split cotter pins and put them in, so I now have to rationalize that was the best thing to do. :D
you will spend more in fuel to get either so the price of the pins seems inconsequential.
lynch pins will also outlast cotter pins by at least 20 to 1 so in the end I think its a wash.
They are also require no tools to install or remove.
   / Losing pins off the back of the tractor #27
No offense, but I hate those lynch pins...............I've got a dozen or so scattered over my 2 acres.
I think they were purposely designed to become dislodged by small twigs just to mess with tractor owners.:laughing:
you can buy them with a retainer ($3 each is kinda expensive) or make your own. then you are not scrounging
around for one each time you hook up and they don't get lost as easily.
   / Losing pins off the back of the tractor #29
The chain is there to grab the weeds and then pull the lynch pin open.
The black heavy duty lynch pin on the right side of the page is the one I use for .99 buy some extras to have on each implement.
   / Losing pins off the back of the tractor #30
A bolt with a locknut is tops for me. I have lost both spring pins and lynch pins at times. Safety wire also helps.
   / Losing pins off the back of the tractor #31
Use the black ones that Steve mentioned. If they snap closed when you're not ready for it they'll put a nice dent in your fingernail. :D I keep a handful of spares in my toolbox on the tractor and another handful in the truck. No need in getting shut down on a job for a buck. Talk about a dollar waiting on a dime... ;)
   / Losing pins off the back of the tractor #32
That's the way I had it figured also.
   / Losing pins off the back of the tractor #33
I just may give those a try when my cotter pins wear out.
   / Losing pins off the back of the tractor #34
I've practiced my sailor terminology a few times when one closed at the wrong time. :eek: Never lost one though!
What about these? Seems like they're even better than the circular snap-pins, and even less likely to dislodge. Or not?
   / Losing pins off the back of the tractor #36
I have used those (not for a tractor) and they seem to stretch out after time and I find myself having to try to collapse them a little every time I use them.
   / Losing pins off the back of the tractor #37
It depends on what you're trying to secure, but I do use those for pins through the holes in the extendable lower arm links and also the safety pin on my trailers coupler. Extras in my toolbox as well.
   / Losing pins off the back of the tractor #38
I've even lost locking lynch pins while plowing new ground that had some low thorny bushes on it. Both the bolt with the nylocks or the safety wire will solve the problem. A couple of feet of electric fence wire in the tool box with a pair if pliers or vice grips are handy things to have with you.
   / Losing pins off the back of the tractor #39
Those things are worthless, as far as I'm concerned. I had one pull out of the gauge wheel post on my 62D MMM. Didn't even know it was gone until I went to lift the deck into the air with the forks to pull the blades and the gauge wheel fell out.
   / Losing pins off the back of the tractor #40
Then what did you replace it with that wasn't "worthless"?
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58216)
2014 MAGNUM...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
Yanmar YT359 (A53317)
2018 KOMATSU WA320-8 WHEEL LOADER (A60429)
2018 KOMATSU...
