MandySue
The mower will start and run, but when i engage the PTO it shuts the mower off. Any ideas what may be happening? Anything i can do or check to troubleshoot this problem? Thank you so much for any help!
Sounds almost like a seat switch fault.
The mower deck is very clean inside and out. I also checked the belts and they appear to be fine and in place. I understand the mower would bog down in tall grass, but the blades will not engage sitting on the driveway
I agree. Most likely a seat switch if the blades are clear and nothing is jammed in the belt(s).
MandySue said:Im not sure the model other than LS 35. It is a hydrostat mower. If the pedal is sitting slighty to the reverse how do you correct that?
unless i unengage the blades quickly and the mower will keep running
