Buying Advice 5075M or 5085M
/ 5075M or 5085M #1
MidGALandscaper
Middle GA
JD4310
I am going to sell my cab 4720 tractor and order me either a 5075M or 5085M. I have about 60 acres of land that I want to do some small scale row crop farming. Beside a hp and price difference, is there anything else that stands out between these 2 tractors?
/ 5075M or 5085M #2
someone mentioned differences in the hydraulic valve option where the 5085M had more options, don't know myself.
/ 5075M or 5085M #3
The main difference is the engines. The 5075M has a 5 cylinder 3.0 liter turbo diesel. It does not have wet sleeves they are cast in the block. The 5085M has a 4 cylinder 4.5 liter turbo diesel. It has the wet sleeves, individual replaceable cylinder liners. This model is 10HP more. There are other versions of the 4.5 liter diesel pushing out a lot more HP. It's 50% larger displacement engine, 4.5L vs 3.0L.
The 5085M has approximately 4 gallon per minute higher hydraulic pump volume. Cab version will hold 6 gallons more fuel and weigh about 600lbs more than the 5075M.
You can get the same transmissions and hydraulic valves on both.
/ 5075M or 5085M #4
Zebrafive pretty well nailed it. My vote goes for the 5085M...
I would try and keep the 4720 if at all feasible, the CUT's are much nicer to operate than the larger tractors with their HST transmissions.
/ 5075M or 5085M #5
Have you called your dealer to see what the price difference is between them? I'd go for the bigger engine, but right now I'd be doing good to afford a 4 hp harbor freight engine. :)
/ 5075M or 5085M #6
My 5520 is a 276 cu in, 86 HP, 4.5 and it is a much more stout than the smaller tractor. It is a real mass of machine that is good on fuel and is as good at tillage as it is at tip-toeing through the corn rows. I plan to keep as long as I am around.
/ 5075M or 5085M
Thanks for all the replies guys. Just what I was looking for. I am going to go with the 5085M. As soon as I sell my 4720.
/ 5075M or 5085M #9
Yep, just the engine and hydraulic output.
Smitty,
Just a few suggestions.
Go with the 16x16 Power Reverser transmission option. You'll be glad you did.
Radial tires. Much better ride plus greater ground contact. Really helps put all that hp to the dirt.
540/540E PTO is a must. Most of the things you do with that tractor can be done in 540E mode. That's 1700 rpm -vs- 2100 rpm. Big fuel savings. (just looked at JD website and saw that the 540E is now standard equpiment) :thumbsup:
Electrohydraulic 3 pt hitch. You'll wonder how you ever got by without one.
Go ahead and order the outside mirror kits. The one in the cab is useless.
/ 5075M or 5085M
Thanks for the suggestions. I like the 16x16 power reverser transmission and definitely love the 540E pto. I want some wide radial tires, something similar to the ones I see on some of the European models (5100R series).
/ 5075M or 5085M #11
View attachment 277616View attachment 277617
Get the radials. When I bought my 5520, I traded off the bias ply tires with a tire shop and put Firestone radials all around. 18.4-34 rear and 12.4-24 front. I got a good trade-in value on the originals since they were new and the radials makes a profound difference in flotation and traction. I have 2 rear weights on each side and if I add some front end weights, can pull an 8 shank heavy Deere chisel plow fairly easily. Similar tractors without the tires don't have a chance.
By the way, you can use the earier Deere suitcase weights--they fit fine.
/ 5075M or 5085M #12
You won't be disappointed with the 5085M. I just picked one up earlier this year with the 16x16 power reverser and the largest radials available. 13.6/24 front and 420/85R34 rears. Fronts are great, but I wish the rears were wider since I brought the rear tires out to be flush with the fender extenders, it leaves a lot of empty inside space that I would have liked to have ground contact for less pressure. I have a pair of weights on each rear and no liquid for a better ride.
/ 5075M or 5085M #13
If you get the 5075M you will get the old style of tractor I believe, then for the 5085M you get the new IT4 styling, I just ordered one yesterday.
