72 ford 4000
/ 72 ford 4000 #1
Con4000
Co Tyrone
72 ford 4000
Hi, I have a 72 3cyl diesal ford 4000, I just installed a new generator and when the tractor is ticking over the battery light is on. It will go off when you rev her up to 800 rpm. What cud b wrong. I checked when she is running it is charging fine. Thanks.
/ 72 ford 4000
Hi, thanks for Info. This did not happen with my old generator? It went out just after starting. Is it true that the dynamo has to b polarised for the first time? also my tractor idles about 600 rpm shud this b adjusted.? Thanks.
/ 72 ford 4000 #5
if it's charging at 750 to 800.. then it IS polarized... no need to re-polarize.
as has been said here and in the other threads you started. gennies don't charge at low idle.. yours is normal.
your previous genny was not the correct genny for this application...
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
2020 Chevrolet Tahoe SUV (A64557)
2020 Chevrolet...
2014 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2014 CATERPILLAR...
JOHN DEERE 7330 PREMIUM TRACTOR (A64280)
JOHN DEERE 7330...
NATIONAL CRANE NBT50 (A65643)
NATIONAL CRANE...
ATS Mini Excavator (A66285)
ATS Mini Excavator...
